How Joburg’s energy-from-water-pipes will work
The City of Johannesburg plans to generate electricity from its water pipe system using in-pipe turbines – here is how it will work.
Water pipe electricity
City of Johannesburg mayor Parks Tau announced in his 2015 State of the City address that Joburg will harness energy from water flowing through its citywide pipe system using in-pipe turbines.
Electricity using water pipes made headlines earlier this year after a 200kW system installed in a water pipeline in Oregon came online.
The system in Oregon uses the LucidPipe Power System – which works by taking conventional water pipes and replacing them with Lucid Energy’s pipes. The new pipes are fitted with turbines, and as water passes through the pipes the turbines spin and generate electricity.
“As velocities increase, power production increases. Due to the lift-based design of the LucidPipe turbine, the system generates power across a very wide range of velocities,” said Lucid Power.
The company said the design of the turbine does not interrupt water flow and allows for power generation at low pressure levels.
“One mile of 42-inch diameter pipeline could produce as much as 3 megawatts or more of electricity.”
How it works
The LucidPipe Power System uses the flow of water inside a water pipeline to spin turbines that produce electricity.
The hydrodynamic turbine is designed to maximize efficiency and power generation while limiting the onset of cavitation. As velocities increase, power production increases.
LucidPipe Power System illustration
Due to the lift-based design of the LucidPipe turbine, the system generates power across a wide range of velocities.
LucidPipe extracts very little head pressure per turbine, often 1-5 PSI. This feature allows the modular LucidPipe system to be placed in series, while allowing for uninterrupted water flow.
Water pipe alternate
LucidPipe does not need to be placed in a pressure transient zone or where extreme differential pressures are needed.
Many in-conduit hydropower systems are designed to replace pressure reduction valves in small-diameter pipelines 16 inches or less. LucidPipe works in conjunction with valves in large-diameter pipelines ranging from 24 – 96 inches.
Power pipe
Power pipe
LucidPipe Power System installed
Using LucidPipe and valves together increases the life of valves, while simultaneously reducing energy costs.
LucidPipe is designed to minimize any impact on water operations.
LucidPipe arrives mounted inside a pipe section. The pipe section is installed directly into the water transmission pipeline in a day and grid connected within a week.
Lucid Energy
Lucid Energy
Inside water pipe
Inside water pipe
LucidPipe can be placed throughout a pipeline system in series without disrupting water delivery. In low-flow conditions, LucidPipe can be deactivated and have virtually no impact on pipeline efficiency.
The video below gives an overview of how the system works, and what the advantages are.
More energy news
Johannesburg to keep lights on during load shedding
Delays at Medupi
Eskom has huge power grip over South Africa
Share your thoughts
Join the conversation
Connect with Us
androidappletwitterfacebookgoogleplusfeednewsletter
Do you think the ANC is limiting the growth of broadband connectivity in South Africa?
More News
Microsoft “tricks” users into upgrading to Windows 10
Windows 10 logo
Microsoft has been accused of changing the pop-up box asking Windows users to upgrade to Windows 10 to schedule the upgrade if the red “close” cross is clicked.
Seacom in the market to buy Internet companies in South Africa
Seacom logo wood
Neotel would be one of its targets, said Seacom.
Soweto residents do not have to pay outstanding Eskom electricity bills
Eskom blue logo
Eskom will waive Soweto residents’ debt repayments as an incentive to convert to prepaid meters, it was revealed in a written reply in Parliament by the Department of Public Enterprises.
How Netflix helped ShowMax in South Africa
ShowMax On Screen photo
Netflix launching in South Africa has been positive for ShowMax, with a big spike in activity on its website following the launch.
Newsletter Subscription
Name
Email *
Enter the following to confirm your subscription *
Captcha image
Free MyBroadband Newsletter
Subscribe
