NETGEAR’s Powerline Wireless Range Extender
Brawler
http://www.netgear.com/Products/PowerlineNetworking/PowerlineWirelessAccessPoints/WGXB102.aspx
Receive Wireless Internet Access from any Power Outlet in Your Home
Provides easy wireless access to existing home network
Turns any electrical power outlet into a network connection
Extends a network to any room in your home¹
No software required—just plug and play!
Compatible with wired/wireless cable routers & modem router
Features
Uses standard electrical sockets and existing electrical wiring
No need to install Ethernet cables
Compatible with 802.11b and 802.11g wireless devices
Sleek platinum casing
Easy web-based user interface for setting up and changing security settings
Supports Windows® Vista™
Extend your network throughout the house¹
anyone used this?
