Results 1 to 7 of 7
Thread: Sub repair or replacement?
  1. #1
    Super Grandmaster
    Join Date
    Feb 2007
    Posts
    29,608
    Unhappy Sub repair or replacement?
    I have an old Cambridge SoundWorks Desktop Theater 5.1 system which I'm currently using as a home theater while I patiently shop for a decent 7.1 component system...
    Unfortunately the sub has started to pack up, it either doesn't work, or the bass sounds like a cracky speaker - bad description, I know. I'm not sure if this is just the wiring in the sub - its a passive sub, so I don't think there could be much wrong with the wiring - but I can't get it open.
    Can I just use a cheap passive sub? Or how can I get this working again while I search for the 7.1 system?
    Currently my TV, PS3, Music, etc run through this - so its kinda important to me.
    Pic of system:
  2. #2
    Grandmaster IceBlade84's Avatar
    Join Date
    Dec 2008
    The Ice Palace
    Posts
    1,720
    Default
    Quote Originally Posted by xrapidx View Post
    I think it's ether the two wires that go to the membrane that has gotten loos or the membrane is damaged, both would require the replacement of the driver.
    A cheap passive sub would work if it has the same connection and power rating (RMS watt) as the old one. Just be careful as passive subs dont have the same amount of magnetic shielding as mre expensive ones.
    Well the power rating should be the same or higher, preferably higher. Weve blown a cheap sub with a higher quality amp.
    Milkmag
    Milking the net for all it's worth.
    Life is allot like death, it happens to everyone, even if they like it or not.
  3. #3
    Grandmaster
    Join Date
    Oct 2007
    South of the Jacarandas and north of the Jukskei
    Posts
    3,692
    Default
    Oh, I thought this thread is about submarines...
  4. #4
    Default
    haha lol
    The liver is evil... and must be punished
  5. #5
    Super Grandmaster
    Join Date
    Feb 2007
    Posts
    29,608
    Default
    Quote Originally Posted by IceBlade84 View Post
    Thanks - the plug on the sub is the standard AV type plug.
    What is the driver? Is it not possible to resolder the wires?
  6. #6
    Join Date
    Dec 2008
    The Ice Palace
    Posts
    1,720
    Default
    Well if you can find one that also has an AV plug, then it should work. Make sure if you're had external power that the new one also has external power.
    The driver is the sub speaker. I don't really know if you'd be able to fix it. You could try to use some glue, but if the wire in the coil on the membrane is damaged, then it won't really help.
    Milkmag
  7. #7
    Super Grandmaster
    Join Date
    Feb 2007
    Posts
    29,608
    Default
    The sub had no external power - just the lead to the receiver/amp. I've always been surprised at how well this system performs. . . in comparison to your standard HTIB 5.1 home theater's - it's always been way better.
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
