Hi guys,
There always been allot of questions and problems about pings and DC's in 25 mans when playing from SA. I've raided seriously allot, althou I've been retired for a while I've had my HM drakes, Starcaller title etc for a while now and I've also had the LAG & DC problems in Naxx 25, in Ulduar 25 on boss fights, latency spikes and just **** latency in general.
Being a serious raider I had to fix it and I did spend allot of time to get to the bottom of things. (I use Windows XP SP2)
* 1stly with your ADSL line the Line Attenuation (the lower the better!) & Noise Margin (the higher the better) is VERY important. Make sure yours are good! You can google it, these forums has other topics about it also. (added: http://mybroadband.co.za/vb/showthread.php?t=46156)
Make sure you have filters on the telephones on the line and unplug Fax machines if you can, they add allot of Noise etc.
Report an Intermitted Fault to Telkom so they can test and maybe fix your line a bit. (they can quickly do a port reset while u are on the phone with them also)
Its a fact that these to little things on your line WILL cause you lag & DC's!
I cannot begin to tell you how important a good Line Attenuation & Noise Margin is!!! You want Line Att under 40 & Noise Margin above 13 and u will def be sorted.
* ADSL accts.
- Normal telkom Based accts are ****, never use them
- Unshaped telkom based accts are OP, I used to use an Axxess Prepaid Unshaped Saix based acct
- Before I 'retired' Semi shaped or 626 (I also used Axxess) started to work fine (this was after the seacom things)
626 accts are cheap and they work most of the time, if there where problem times I always had an 1GB unshaped prepaid to help me out
* BUT most importantly I made use of Lowerping (www.lowerping.com) service (tried all others like gamemax.org and they did not work properly, have not tried http://www.gamepath.net/ , but I know they are a bit cheaper) With lowerping (putty & sockscapv2 on Xp) I get +- 250ms pings with an Saix Unshaped acct and +-290MS with Semi-shaped / 626 accts (seemed these IS based accts was 'fixed' after seacom)
* You can also change the TcpAckFrequency of windows. It might or might not work for you, so give it a shot if you want. I will paste crap about it @ the bottom of this post.
* Another thing that I found on the WOW forums and google is to change some settings on your Network card itself. (properties on your Lan/network card connection) I don't have what to change with me now sorry.
It was also mentioned to delete your network card from device manager, restart pc and let it reinstall or reinstall it. Sometimes some sortware etc changes things and a fresh 'restart' of it might help.
I did all the above things and I was raiding seriously Naxx & Ulduar for some time without a single latency related DC using the above things. My ping was always between 200 - 250ms except when there where SA network problems (**** happens hey)
I really hope this helps some of you guys who are still having problems. It worked for me.
*Note* I reinstalled my Windows XP SP2 (this XP) yesterday 09 Oct, did the TcpAck fix, loadeded Lowerping with SocksCapV2, logged on wow and there I was standing in dalaran with my 80fps looking @ the green connection computer saying 279ms while connected with my Afrihost acct. I was flying around, casing heals etc and latency stayed that why. Tonight I will test it in the raids.
GL HF
TcpAckFrequency - Not saying it will work for you, but you can try it
Look @ the following addon: http://www.wowinterface.com/download...atencyFix.html (updated for Win7) Thx to Pornolio for info/link - This is what I use
WoW lags, it's not something new if you're playing on servers a bit far away from your country, but don't worry people are fixing it ! Out of all the methods offered to fix the lag on your machine, one of them posted on Elitistjerks forums seems to work very well.
<> <> <> Read this first <> <> <>
1 - It might have side effects, like slowing down your download speed or affecting your performance on other softwares. (In my case, it didn't change anything)
2 - If you're not sure about what you're doing, just don't do it. I don't want to be responsible because you crashed your computer in some way because you wasted your registry.
2.1 - Seriously, if you don't know what you're doing, don't do it. It will be fixed in one or two weeks anyway. (and the official fix won't have any impact on other softwares)
3 - If you don't have the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSMQ\ directory, you can download and apply this file to your registry.
4 - Windows Vista users might want to check this post too.
Source - Elitistjerks.com
"1 - TcpAckFrequency - NOTE if you are running Windows Vista this setting may not have any effect - a hotfix is needed which i'm tracking down. This works fine under Windows XP
Type "regedit" in windows "run.." dialog to bring up registry menu
Then find:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Tcpip\Parameters\Interfaces\
There will be multiple NIC interfaces listed in there, find the one you use to connect to the internet, there will be several interfaces listed (they have long names like {7DBA6DCA-FFE8-4002-A28F-4D2B57AE8383}. Click each one, the right one will have lots of settings in it and you will see your machines IP address listed there somewhere. Right-click in the right hand pane and add a new DWORD value, name it TcpAckFrequency, then right click the entry and click Modify and assign a value of 1.
You can change it back to 2 (default) at a later stage if it affects your other TCP application performance. it tells windows how many TCP packets to wait before sending ACK. if the value is 1, windows will send ACK every time it receives a TCP package.
Added 07/10/09
Having latency issues on Windows 7 RC? Try this:
1. Go in under Control Panel / Network and Internet / Network connections.
2. Right click your internet connection and choose Properties.
3. Under your network device at the top, click Configure...
4. Under advanced, disable everything that ends with "Checksum Offload".
5. Profit.
Edit: Note that this workaround is only tested under Windows 7 RC
FPS Related:
There are two graphics settings that are an absolute killer for fps. Once is reduce lag input or some such thing and the other is the shadow setting. Move it one tick below max and it makes a massive difference. Full shadow atm is a pc killer.
*edit* more info @ http://mybroadband.co.za/vb/showthre...=205088&page=2 post 19
Spam Related:
*edit 20/04/10* Hi all, Its been a while since anything has been added here. Personally I have not had any real DC's for ages, but I received a pm from delta_brad who said he was still having DC's in 25 man raids.
"I came across this very handy addon that blocks other addon spam. Sorted my DC problems in 25mans right away. The only downside is that the addon ignores players with addons that spam and then unignores them when the fight is over"
SmartAddonBlocker @ http://wow.curse.com/downloads/wow-a...onblocker.aspx
Some other spam related addons of note:
FuBar_AddonSpamFu @ http://wow.curse.com/downloads/wow-a...n-spam-fu.aspx
Spydon@ http://www.wowinterface.com/download...10-Spydon.html
GL
Lightbringer (EU)
Bookmarks
