You should join our great online community now
Register now
You should subscribe to our free MyBroadband newsletter
Results 1 to 15 of 15
Thread: Wider tyres and fuel economy.
  1. #1
    Default Wider tyres and fuel economy.
    My Jetta 4 TDI has 16 inch tyres, the tyre size currently is 205/55/16, so the tyres is 205 wide. I know of someone who fitted 225 tyres on a Audi with the same size wheels as my Jetta.
    So I've been thinking of doing the same when I must replace mine. What do you think, will the 20 mm wider tyre interfere with the fuel economy?
  2. #2
    Super Grandmaster
    Join Date
    Aug 2005
    Underberg, KZN
    Posts
    5,178
    Default
    It surely would. Dont know to what noticeable extent though.
    "The greatest shortcoming of the human race is our inability to understand the exponential function." - Dr. Albert Bartlett
  3. #3
    Super Grandmaster Fazda's Avatar
    Join Date
    Apr 2009
    Why not Zambia? or /\/ŻŻŻŻŻ\/\ ?
    Posts
    11,263
    Blog Entries
    13
    Default
    There is possibly a fine line here between the wider tyre giving you slight overgearing, and theoretically lower revs at speed, and consequently better fuel consumption v/s the increased rolling resistance actually making the consumption worse....
    Probably would be negligible.
  4. #4
    Default
    I saw almost no increase in my fuel consumption after going from 155 to 185, so I don't think you will. This was using exactly the same brand and model tyre for both sizes. Your Jetta's pretty light already - it's a TDi
  5. #5
    Default
    Quote Originally Posted by Fazda View Post
    See it's only the width that will differ, the hight and size is the same.
    Just thought the 20 mm will give a better handling on the open road, or am I wrong?
  6. #6
    Join Date
    Apr 2009
    Posts
    11,263
    Blog Entries
    13
    Default
    No you are not wrong, the only thing the width will do is increase your rolling resistance.
    Years ago manufacturers used to publish their fuel consumption figures based on the base model with the skinniest tyres, as they provide less rolling resistance, and consequently better consumption
  7. #7
    Super Grandmaster ponder's Avatar
    Join Date
    Jan 2005
    KZN Dolphin Coast
    Posts
    55,123
    Default
    The girls will agree with that
    entia non sunt multiplicanda praeter necessitatem
  8. #8
    Default
    I actually think it just looks ugly with fatter tyres...
    Narrower tyres FTW!!!
  9. #9
    Grandmaster blaaislaai's Avatar
    Join Date
    Mar 2007
    Strand, Western Cape
    Posts
    4,627
    Default
    I went from 14" to 17" on my jetta 3, Have not noticed any change in fuel consumption.
    What I do have noticed is, there's more grip on the road and it's not so easy spinning the wheels anymore. Which I don't do anyways.
    +1 on the grip. Love it
    Gebore om te kuier, gedwing om te werk!
    BitCoin mining, generate money daily! https://hashocean.com/signup/?rid=333617
  10. #10
    Default
    So its safety vs consumption?
    DEL PythonFSi
  11. #11
    Join Date
    Apr 2009
    Posts
    11,263
    Blog Entries
    13
    Default
    Quote Originally Posted by PythonFSi View Post
    You could put it that way, but it was never an issue with manufacturers...they simply wanted to publish great fuel consumption figures...99% of the owners changed to wider tyres any way, and then wondered why they coul never match claimed consumption figures...those BBS mags look great BTW
  12. #12
    Join Date
    Apr 2009
    Posts
    11,263
    Blog Entries
    13
    Default
    Quote Originally Posted by blaaislaai View Post
    If you go from 14 to 17 with the correct aspect ratio, there probably won't be a difference, unless you are measuring it on all sorts of electronic gimmickry
  13. #13
    Default
    Well I dont think there will be a much noticed safety difference from 205 wide to 225. The outer size is also the same, so speed wont be affected too.
    But I phoned today just to get a figure on the cost difference, Michellen tyres, 205 R1300, 225 R2000. So hell no, I wont pay that just for a little bit wider tyre. Didn't think it will cost so much more.
  14. #14
    Grandmaster
    Join Date
    Dec 2003
    Roodepoort, Johannesburg, South Africa.
    Posts
    2,040
    Default
    Safety wouldn't really be much different. Your grip is determined by your downforce not your tyre area. Sure you might have a 10% larger contact patch, but every piece of rubber is 'pushed' onto the road with less force. If you don't 'push' the tyre onto the road, it doesn't grip. Some scenarios might actually be more dangerous with wider tyres. A bigger area means you'll have to displace more water for instance, so your car is more likely to aquaplane.
    A wider tyre would increas rolling resistance, and the slight increase in friction could increase your fuel consumption. Check out a few of the cars used for these mileage test, they usually have hecticly thin tyres.
    Additionally, wider tyres might upset your car's designed suspension geometry, which could reduce grip in certain conditions. If the centre of the tyre is in a different position, you're also likely to put strain on wheel bearings that they weren't designed for.
  15. #15
    Join Date
    Apr 2009
    Posts
    11,263
    Blog Entries
    13
    Default
    Quote Originally Posted by Pyro View Post
    EXCELLENT Post Pyro...100% behind you on that one
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
