You should join our great online community now
Register now
You should subscribe to our free MyBroadband newsletter
Results 1 to 15 of 15
Thread: What is the difference between ISDN and ADSL (Telkom)
  1. #1
    Default What is the difference between ISDN and ADSL (Telkom)
    Please can you help us with this issue!!
    We are having great debates in our technical ignorance.
  2. #2
    Super Grandmaster PostmanPot's Avatar
    Join Date
    Jul 2005
    Posts
    34,950
    Default
    ISDN still uses normal call charges per minute/R7 call plan, ADSL is one fixed monthly fee for 24 hour internet.
    ISDN comes in 64k and 128k (you will have to pay for two calls to get 128k), ADSL comes in 192k, 384k and 512k.
    ISDN is "uncapped" so you can download as much as you want, ADSL is normally capped from between 2gb of downloads to 30gb of downloads, unless you can afford uncapped.
    speaking of which, Web Africa have a new promotion for myADSL members.. 30gb cap + ISP charges for R199 p/m.
    peace
  3. #3
    Join Date
    May 2005
    Posts
    293
    Default
    Integrated Services Digital Network. A switched network providing end-to-end digital connectivity for simultaneous transmission of voice and/or data over multiple multiplexed communications channels and employing transmission and out-of-band signaling protocols that conform to internationally-defined standards.
    ADSL (Asymmetric Digital Subscriber Line) is a technology for transmitting digital information at high bandwidths on existing phone lines. Unlike regular dialup phone service, ADSL provides a continously-available connection. ADSL is asymmetric in that it uses most of the channel to transmit downstream to the user and only a small part to receive information from the user. ADSL simultaneously accommodates analog (voice) information on the same line. ADSL is generally offered at downstream data rates from 512 Kbps to about 6 Mbps.
    From google.
    Probably the most noticable difference is that the one is dialup and the other is an "always on" connection.
  4. #4
    Grandmaster
    Join Date
    May 2005
    London. Hometown: Durban
    Posts
    1,310
    Default
    isdn as far as i know is also unshaped, adsl accounts come standidly shaped but for a bit more u can get unshaped
  5. #5
    Join Date
    May 2005
    Posts
    293
    Default
    Quote Originally Posted by Silent_Bob
    isdn as far as i know is also unshaped, adsl accounts in South Africa with Telkom come standidly shaped but for a bit more u can get unshaped
    Fixed.
  6. #6
    Join Date
    Jul 2005
    Posts
    34,950
    Default
    heh
  7. #7
    Banned
    Join Date
    Jul 2003
    Durban, South Africa
    Posts
    1,576
    Default
    ADSL modulates a digital signal onto a high frequency portion of your phone line. The difference between this is that the signal is added and removed (at the DSLAM) before the analog line is terminated into the exchange. With modem the limiation is that the signal is carried as a voice portion, switched through the exchange (at around 46Khz iirc)
    ISDN is a digital switched line end to end - each line is 64Kbit/s (two bonded for 128K). Stuff like diginet is a bunch of multiplexed 64Kbit lines. ISDN uses HDLC frames, ADSL uses ATM frames.
  8. #8
    Default
    ISDN: Dial up
    ADSL: 24/7 connection
    E8400 E0 @ 4.0Ghz | TT Typhoon VX | GA-P35-DS3L | Transcend 2 x 2GB DDR2-800 | Gigabyte 9600GT @ 800Mhz Core| 2 x 1TB HDD | CM 650W PSU | GZ-X1 | T260
  9. #9
    Grandmaster
    Join Date
    Apr 2005
    EL
    Posts
    2,476
    Default
    ADSL is better
  10. #10
    Default
    if its available in your area
    "If the ANC does to you what the apartheid government did to you, then you must do to the ANC what you did to the apartheid government." Nelson Mandela
  11. #11
    Default
    ISDN is better for international latency if you're into online gaming on overseas servers.
  12. #12
    Default
    Errrr not true.
    Unshaped ADSL latency is slightly lower than that of ISDN
    EDIT: Internationally that is - ADSL is obviously unshaped locally, so the latency on any ADSL is lower than ISDN to local servers
  13. #13
    Default
    In my experience if you are using it for anything to do with voice, ISDN seems to be better...not sure what the reason is but thats the way it has been for me
  14. #14
    Default
    ADSL = cool
    ISDN = not cool
    Please save trees and think twice before printing this post.
    Looking for a VPN, read my reviews at vpn-reviews.net
  15. #15
    Default
    Quote Originally Posted by James
    ADSL = cool
    ISDN = not cool
    Correction:
    ISDN = cool when you can't get friggin ADSL!
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
