You should join our great online community now
Register now
You should subscribe to our free MyBroadband newsletter
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Thread: Which decoders will be able to decode toptv, dstv, free to air from 1 decoder
  1. #1
    Join Date
    Dec 2009
    Cape Town/ Mitchells Plain
    Posts
    129
    Default Which decoders will be able to decode toptv, dstv, free to air from 1 decoder
    Hi there all
    I have been searching the net for some time now to find a all in one decoder that will be able to decode the above mentioned.
    Any suggestions?
    and please dont tell me dreambox, i would like some other brands that would do the job.
    Thanks.
  2. #2
    Default
    Quote Originally Posted by bevan1 View Post
    Hi there all
    Any suggestions?
    Thanks.
    You can stop searching now. There is no STB that can do that.
  3. #3
    Join Date
    Dec 2009
    Posts
    129
    Default
    Come on there has to be a decoder that would be able to decode both toptv and dstv. According to www.wowtv.co.za they will get a decoder that will be compatable for wowtv, dstv and toptv. So their has to be a decoder(s) out their that does do it.
  4. #4
    Super Grandmaster Nerfherder's Avatar
    Join Date
    Apr 2008
    /\/ŻŻŻŻŻŻ\/\
    Posts
    20,425
    Default
    Dude.... if such a thing existed we would all have one.
    "What can be asserted without proof can be dismissed without proof." ~ Christopher Hitchens
    My idea of "Help from above" is a sniper on a roof.
  5. #5
    Grandmaster
    Join Date
    Nov 2009
    Posts
    1,197
    Default
    ah, but there are. just not in sa, and more than likely illegal (or they will attempt to play that card on you). otherwise, it takes a degree in some or the other engineering to sort it out yourself. hell, scour the web, you might even find a program that will do it for you, provided you have the right equipment in your pc. somewhat along the lines of being able to hack your m-net decoder several years back. they change the signal very often nowadays to prevent that though
  6. #6
    Grandmaster blaaislaai's Avatar
    Join Date
    Mar 2007
    Strand, Western Cape
    Posts
    4,658
    Default
    Quote Originally Posted by Quantum Theory View Post
    And never will be.
    Gebore om te kuier, gedwing om te werk!
    BitCoin mining, generate money daily! https://hashocean.com/signup/?rid=333617
  7. #7
    Join Date
    Apr 2008
    /\/ŻŻŻŻŻŻ\/\
    Posts
    20,425
    Default
    Quote Originally Posted by Kaine View Post
    Well it would be possible except all the providers in SA encrypt their signals so unless you have the exact hardware you are not going to get it right.
    Well lets just say that there will never be a commercial device that does it.... unless DSTV and TOP TV both decide to change the way they do things.
  8. #8
    Default
    Quote Originally Posted by Nerfherder View Post
    TopTV uses the same encoding as BSKYB in the UK and Multichoice uses IrdetoII. You need to emulate both types of CAM in one box. You can do it with a software emulator (EMU) or with maybe an external card reader which matches the voltage for a specific card. We're not talking about cloning the card, just reading a valid subscription card. There are STB's that can do it, but most need a lot of tweaking to get it right. The advanced Dreambox decoders can do it, or so I've heard.
  9. #9
    Join Date
    Dec 2009
    Posts
    129
    Default
    Let me just state this before people get the wrong impression. I do not want to hack the decoders. All i want is a decoder that will be able to read Multichoice, Toptv smartcards without chopping and changing the two decoders.
  10. #10
    Join Date
    Apr 2008
    /\/ŻŻŻŻŻŻ\/\
    Posts
    20,425
    Default
    Yes... that will never happen.
    Also you do know that the dishes wont even face the same way ?
  11. #11
    Super Grandmaster ToxicBunny's Avatar
    Join Date
    Apr 2006
    Crimetown
    Posts
    55,779
    Default
    Beyond the encrpytion issues the box would have to overcome, there is also the location of the satelites.. you will need a dish that has almost no obstructions over a LARGE portion of the sky, as well as to be able to alter its own position.
    Quote Originally Posted by Korn1 View Post
    I have been called a retard my whole life
  12. #12
    Grandmaster
    Join Date
    Jan 2006
    Westville, Durban
    Posts
    2,696
    Default
    Quote Originally Posted by ToxicBunny View Post
    I would assume if the encryption was possible you would have 2 dishes & have an LNB feed from each dish as a separate inputs on the decoder
  13. #13
    Default
    Two dishes with a 2-way DiSEqC switch into one decoder would be the solution, but the different encryption standards and the whole smart card marriage thing makes this impossible.
  14. #14
    Join Date
    Dec 2009
    Posts
    129
    Default
    You talking about smartcard marriage. Who is the ower of the decoder that you bought? Does it belong to Dstv or Toptv? Did you not spend your money on it? If the decoder does belong to you then who gives them the right to marry your smartcard and decoder? And who gives them the right to update your decoder and at the end of the day the update was not successful and you sitting with a door stopper.
    They come up with all the excuses that it's to prevent fraud. But if i have a decoder at at my holiday house and home, i just want to pack my smartcard , now i cannot. Funny
    Come on People. If you buy something its yours and no one else.
  15. #15
    Default
    This is a common misconception. Smartcard marriage generally only prevent you using another MC or TT box. Using a 3rd party box removes (most) of these problems. For example you can quite happily use an MC card with a Dreambox despite the card marriage system. It just doesn't look for it.
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
