What determines the speed of an USB dongle? E.g. Cell C have 2 different dongles, obviously both should work on 900MHz but one of them is advertised as maximum 7.2Mbps, the other 21Mbps. So what other specification on a particular modem one is to look for in order to determine the maximum speed?
The only time you'll need the higher speed one is if your received signal strength (yes, improved by an external antenna) is high enough to warrant you getting anything higher than your current dongle's maximum HSDPA rate.
Bookmarks
