Results 1 to 9 of 9
Thread: PWM controller for dual Sickleflow 120mm fans?
  1. #1
    Super Grandmaster
    Join Date
    Feb 2009
    Stellenbosch
    Posts
    8,099
    Blog Entries
    1
    Default PWM controller for dual Sickleflow 120mm fans?
    Hi,
    I currently have 2x Sickleflow fans stuck on my ThermalRight Ultra 120 Extreme CPU cooler, but I have to run them at 7V otherwise they make way too much noise.
    So now I'm looking for a PWM controller to adjust the speed of both depending on the CPU's temperature. I'm hoping to get one that I can connect on the 4-pin CPU fan header.
    Otherwise, I'm also open for suggestions for other 120mm PWM fans that I can use.
    It would be a bonus if I can get the stuff from Prophecy Shop, since I'm going to place another order from them today/tomorrow.
  2. #2
    Super Grandmaster Archer's Avatar
    Join Date
    Jan 2010
    Posts
    17,029
    Default
    What version of the sickleflow fans? 1200 or 2000rpm (big power difference between them)? And what board do you have, need to know what the max power is that can be delivered via the CPU fan header.
    GPU Charts: Updated 26/03/12
    Custom Chassis
    Custom Chassis MKII coming soon™
    Domaincheap
  3. #3
    Super Grandmaster
    Join Date
    Feb 2009
    Stellenbosch
    Posts
    8,099
    Blog Entries
    1
    Default
    I have the 2000rpm ones and I have an Asus P6T Deluxe v2 motherboard.
    I saw that you get Artic Cooling fans that can share a single PWM signal eg. http://www.prophecy.co.za/arctic-coo...m-p-66167.html
    Unfortunately that fan isn't 25mm wide, and I can't find the 25mm ones at Prophecy Shop.
  4. #4
    Join Date
    Jan 2010
    Posts
    17,029
    Default
    Why do you need the 25mm ones, it does say they arecompatible with 25mm mounting systems. Looking at max power etc etc now
    Custom Chassis
    Domaincheap
  5. #5
    Super Grandmaster
    Join Date
    Feb 2009
    Stellenbosch
    Posts
    8,099
    Blog Entries
    1
    Default
    Archer, do you reckon you can install that Arctic F12 Pro PWM fan in reverse? Because it's not symmetrical like the 25mm one (Arctic F12 PWM).
  6. #6
    Join Date
    Jan 2010
    Posts
    17,029
    Default
    Quote Originally Posted by Pada View Post
    Ha, I see the problem now You might be able to, but I wouldnt bank on it.
    Custom Chassis
    Domaincheap
  7. #7
    Join Date
    Jan 2010
    Posts
    17,029
    Default
    Ok, page 60 of the manual says the fan connectors can handle 24W each, up to a total of 84W max for all of them together. So even two fans drawing 1A each will be fine on a single connector. So pretty much anything that is PWM controlled will work, you may have to splice the wires together though. Be careful with the wire that reports the speed of the fan, dont think you should splice that. Will look if there is a ready made cable for this (there should be since the Frio cooler on the other PC has two fans that are linked to one CPU header)
    Custom Chassis
    Domaincheap
  8. #8
    Super Grandmaster
    Join Date
    Feb 2009
    Stellenbosch
    Posts
    8,099
    Blog Entries
    1
    Default
    Thanks Archer.
    I think I'll try to build my own PWM circuit instead, like shown here: http://forums.techpowerup.com/showthread.php?t=107135
    Edit:
    Jude (from Prophecy Shop) is currently helping me out with regards to these Arctic Cooling/Silverstone PWM fans...
  9. #9
    Join Date
    Jan 2010
    Posts
    17,029
    Default
    Thanks Archer.
    Edit:
    Ask if you need help with that too, although its pretty simple. The only thing to really watch out for is that you get a transistor that can handle the current. If you get that right you should be good to go.
    Custom Chassis
    Domaincheap
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
