You should join our great online community now
Register now
You should subscribe to our free MyBroadband newsletter
Results 1 to 9 of 9
Thread: Help with Drivers for EasyCap Video Capture USB Device
  1. #1
    Default Help with Drivers for EasyCap Video Capture USB Device
    Hi,
    was wondering if anyone can point me to a link for the drivers for the above device - for winXP/7.
    The same device can be found here: http://www.bidorbuy.co.za/item/24793...RES_CRAZY.html
    Cannot locate driver software CD
    Thanks in advance.
    Victoria Concordia Crescit
  2. #2
    Senior Member Megalin's Avatar
    Join Date
    Aug 2008
    Johannesburg
    Posts
    189
    Default
    I have the same device, i think I have the drives at home somewhere. If they are not too large, i can e-mail them to you? PM me if you want it.
  3. #3
    Default
    Try this link for drivers download: http://www.usbeasycap.info/support.html
  4. #4
    Default
    Quote Originally Posted by geezer View Post
    Thanks - but the links to the drivers seem to be broken.
  5. #5
    Banned D3x!'s Avatar
    Join Date
    Jul 2010
    pew pew pew
    Posts
    18,617
    Default
    I picked up an easycap usb2.0 dc60, like everyone found out it doesn't like to play with windows 7 64bit. Did some hunting around on the net and found another product that looks identical. Sabrent.com EZ Grabber USB 2.0, shot their support team an email they responded with :
    For Windows XP/VISTA/7 32-Bit, please download http://www.sabrent.com/drivers/USB-AVCPT-New.zip to a location you can easily find later (DESKTOP is a good location so you can delete the folder after installation)
    At this point you can update the drivers manually...
    1. Right-Click on MY COMPUTER, Select PROPERTIES.
    2. Select HARDWARE
    3. Select DEVICE MANAGER
    4. Scroll down to the USB Video adapter.
    5. Right Click on the Device and select UPDATE DRIVER.
    6. Do NOT allow Windows to automatically find the drivers.
    7. BROWSE to the Folder you created at the beginning and direct it to the correct folder for your operating system. STK1150 should appear.
    8. Serial Number: 783A2-8A000-05520458
    If the USB-AVCPT does not appear in Device Manager clean without errors (both USB Audio and USB Video/STK1150) you may need do it differently:
    From Device Manager, Right Click on the USB 2.0 Video Video Controller and UNINSTALL.
    ACTION >> Add Legacy Hardware >> Install the Hardware that I manually select from a list (Advanced) >> Imaging Devices >> Have Disk >> Go to the File Folder and Select STK1150 and Select OPEN.
    Windows 7 64-bit:
    http://www.sabrent.com/drivers/USB-AVCPTSetup_For... and run the install program.
    I used their win7 64bit installer and boom driver installed and device is found .. haven't put it through complete test yet but I at least have video being captured.
    Source
  6. #6
  7. #7
    Default
    go to the product website and then to support.
  8. #8
    Super Grandmaster ponder's Avatar
    Join Date
    Jan 2005
    KZN Dolphin Coast
    Posts
    55,472
    Default
    Quote Originally Posted by NoLogic001 View Post
    Their download section is not working, see post above yours.
    entia non sunt multiplicanda praeter necessitatem
  9. #9
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
