Facebook   Twitter    e-mail newsletter    YouTube    RSS Feed    Android App    iPhone and iPad App     BlackBerry App
Results 1 to 15 of 15
Thread: Sony Bravia USB Port on LCD Cannot Read External Hard Drive. Help
  1. #1
    Default Sony Bravia USB Port on LCD Cannot Read External Hard Drive. Help
    Hi
    i noticed on my Sony Bravia 46EX500 (and a few other make LCD tv's / Plasmas) when i plug in my NTFS External Drive it does not pick up the 1TB Drive.
    It works fin on Laptop / Pc.
    1. Does the USB Port only Read FAT32 ?
    2. Which Application can i use to Format the entire 1TB partition to FAT32?
    3. Can i create 2 Partions and just make 1 Partition 2GB and format that as FAT32 and the 2nd Partition as NTFS ?
    4. Will a FAT32 1TB External Drive work on the USB Port on DSTV PVR2 Decoder?
    5. Will a FAT32 1TB External Drive work on the USB Port on a DVD Player?
    thanks for all the help.
    Much appreciated.
  2. #2
    Super Grandmaster PostmanPot's Avatar
    Join Date
    Jul 2005
    Posts
    24,974
    Default
    Hi
    Correct forum - http://mybroadband.co.za/vb/forumdis...and-Multimedia
    Yes it's a file system problem and must be FAT32. Not sure about mixing FAT32 and NTFS on one drive, but you should be able to use Windows Disk Management to do everything. Can be found in Start > right click Computer > Manage > Storage > Disk Management.
    SouthBit Data Recovery - www.southbit.co.za
    Electronic Music
    PM me for cheap computer parts
  3. #3
    Super Grandmaster ponder's Avatar
    Join Date
    Jan 2005
    KZN Dolphin Coast
    Posts
    33,056
    Default
    Many TV's or DVD players cannot use an extern HDD, only usb flash sticks. Only way to be sure is to read the manual or try for yourself.
    1. Yes
    2. Windows, Linux, OS X should all be able to format a drive to FAT32
    3. Yes
    4. No, not as far as I'm aware but I could be wrong.
    5. See very first sentence in post.
    entia non sunt multiplicanda praeter necessitatem
  4. #4
    Default
    Yip, must be FAT32. And to make things a little harder, not all file types are supported. I tried setting my dads system up and some AVI's worked, some didn't. Eventually connected my laptop via HDMI. So much easier.
  5. #5
    Default
    should have gotten a samsung.
  6. #6
    Join Date
    Jul 2005
    Posts
    24,974
    Default
    Quote Originally Posted by Fader4 View Post
    Samsung's don't do NTFS IIRC. Although they do do .mkv... But if the file limitation is 4GB for FAT32, I don't see much of a point to be honest, since most HD movies are bigger than 4GB. I know there are ways to get files >4GB onto FAT32 drives, would they then be viewable? Hmmm.
    Electronic Music
  7. #7
    Default
    Quote Originally Posted by PostmanPot View Post
    samsungs do ntfs and mkv no problem, got a 2tb ntfs drive sitting next to my bedroom tv and watching the new ep fringe right now
  8. #8
    Join Date
    Jul 2005
    Posts
    24,974
    Default
    Awesome. Good to know. I was confused as it seems some guys in the TV forum can only use FAT32? Perhaps difference of firmware? I'm pretty sure the 5 Series LCD's and up, and C450 plasma's and up have the same USB media players.
    Electronic Music
  9. #9
    Default
    Windows 7 won't let you format a large partition with FAT32 (using the native Windows tools.) This will do it for you.
    i7-950 - 24GB - 120GB Intel 510 SSD - 6 x 2TB - 6870 - 2 x 22" - G19 & G9x
  10. #10
    Grandmaster ichigo's Avatar
    Join Date
    Sep 2009
    Pietermaritzburg
    Posts
    4,515
    Blog Entries
    1
    Default
    My Samsung tv also reads my NTFS External Hardrive 250gb
  11. #11
    Join Date
    Jul 2005
    Posts
    24,974
    Default
    Which one? LAxxC530/C550 or upwards? Or plasma?
    Electronic Music
  12. #12
    Default
    Does the Samsung Series 6 LED USB port plays videos ?
  13. #13
    Join Date
    May 2010
    Pretoria
    Posts
    150
    Default
    Quote Originally Posted by JAM007 View Post
    The Samsung LED 5/6 have video support with MKV. It reads off NTFS drives as well.
    You can confirm this on the Samsung website.
    As for converting your drives to FAT32 the best tool for the job is swissknife (Google it) I dont think its advisable to make one partition FAT and the other NTFS.
  14. #14
    Default
    Quote Originally Posted by ost View Post
    I have a samsung 32" Series 6 LED as well and noticed it dont play the .MP4 format.
    will try MKV. files.
    thanks alot. really love MYBB forums. Very helpful.
    thanks to one and all.
  15. #15
    Join Date
    Sep 2009
    Pietermaritzburg
    Posts
    4,515
    Blog Entries
    1
    Default
    Mines LCD, if i remember right it was LA40C530
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
