You should join our great online community now - you can win great prizes
Register now
You should subscribe to our free MyBroadband newsletter
Results 1 to 4 of 4
Thread: wireless Billion 800VGT router from telkom info
  1. #1
    Default wireless Billion 800VGT router from telkom info
    Hello, I have this Billion 800VGT router from telkom with a 364kb/s line, i was wondering cant i somehow enable this so that i do not need to setup the ethernet wire and just by using wi-fi connect to the internet?
  2. #2
    Default
    Well yes, if you know how to. Enable wifi on the router, and on your laptop. Connect it and vola. I use this little excellent router, the included documentation should assist you
  3. #3
    Super Grandmaster
    Join Date
    Feb 2009
    Stellenbosch
    Posts
    8,122
    Blog Entries
    1
    Default
    The router's user manual should tell you how to setup the WiFi.
    I would suggest that you use WPA2 security, with a reasonably long password (8 characters or longer).
  4. #4
    Default
    Can't agree more.Excellent router.Initially had some problems losing wireless connection on a regular basis due to signal interference from other wireless network connections.Problem solved after changing channel on the modem.Used application inSSIDer to check other wnc's channels.
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
