Creating AP with Wireless Router and a 3G Dongle.
Earther
Molopo
Hi to all
I have a 3G dongle and need to distribute internet through out the house (for use on wifes notebook and my Android Tablet + kids computer).
Is this at all possible?
Using Windows 7 and 300N Wireless Router + MTN 3G Dongle.
I read that this is possible in Linux, but not sure in Windows.
Please Help!
Yes this is possible however it is a mission.
It is called internet connection sharing I posted it about it a while ago
http://mybroadband.co.za/vb/showthr...eless-router?p=6819150&highlight=#post6819150
The easier option would be to go to www.dbg.co.za get a 3g router plug your "stick" into the router and you are a for away.
I did the internet connection sharing for a while and it irritated me so much I went and bought a router.
or you could go to incredible connexion or anyone I just found these to be way too expensive.
I just bought one yesteday..Ordered it at 10am and it was delivered by 3:
TP-Link MR3420 3G Wireless N Router (TL-MR3420) = R499.00
Should suit your needs as it has 3G/WAN failover and out the box you can just plug in your modem and go.
