Facebook   Twitter    e-mail newsletter    YouTube    RSS Feed    Android App    iPhone and iPad App     BlackBerry App
Results 1 to 10 of 10
Thread: How to connect a wall plug to telephone wires?
  1. #1
    Default How to connect a wall plug to telephone wires?
    Hi guys,
    I live in a complex and want to get ADSL as I'm sick of having a capped connection (and had uncapped ADSL before while living with my mom). According to the Telkom guy I spoke to the weekend the entire complex is already wired up at the exchange, it is just a matter of connecting the wall socket to the wires and activating the line.
    As installation costs are so high I refuse to pay that amount for something I can do myself provided I know which wires are connected where in the wall socket. The wall socket I can get from builders so that is not a problem.
    There are basically 6 wires: 3 white, 1 blue, 1 orange and 1 green. Can someone point me in the proper direction for which wires are connected?
    I think this will happen everyone living in the complex where the wires are already run to a unit, but just require the wall socket which you connect the phone to.
    Quote Originally Posted by killadoob View Post
    Do you want to die? i can see linux users loading their shotguns as we speak
  2. #2
    King of de Jungle Garyvdh's Avatar
    Join Date
    Mar 2005
    District 9
    Posts
    49,968
    Blog Entries
    21
    Default
    It could be any combination, it depends what colours they used on the other side. But if I am not mistaken it should be the orange and green wires.
    But it is not that hard to figure it our for yourself. Just hook up a telephone and touch various combinations of wires until you get a dial tone.
  3. #3
    Default
    Quote Originally Posted by Garyvdh View Post
    Thanks for the input. That is exactly what I was thinking if I didn't get an answer from anyone.
    Now I just have to phone Telkom and have them do the ADSL installation.
  4. #4
    Default
    Strip 300mm of wire. You'll see that each white is paired with a colour. Use the Blue/White pair.
    Quote Originally Posted by PeterCH View Post
    Windows is ok in general, and sometimes it's necessary
  5. #5
    Join Date
    Apr 2008
    Grahamstown
    Posts
    66
    Default
    Quote Originally Posted by Swift-wp View Post
    I should imagine that if you strip enough insulation back, you'll find that each of the white wires is twisted around one of the coloured wires, making up a pair. As Garyvdh has said, you'll need to look for dial tone: I'd suggest starting with the blue/white pair, then the orange/white and green/white. If you don't find dial tone, chances are the problem lies elsewhere, and a Telkom tech would probably be the best person to find that.
  6. #6
    Super Grandmaster ponder's Avatar
    Join Date
    Jan 2005
    KZN Dolphin Coast
    Posts
    33,960
    Default
    There should be a DB somewhere in the building, make sure that side is also connected. You could loop the pair and then buzz them out in the DB for easier tracing.
    entia non sunt multiplicanda praeter necessitatem
  7. #7
    Default
    What about opening a telkom account, being assigned a phone number, that number being assigned to a port in the exchange, the line to your house being assigned to that port. Putting a RJ11 socket in your house without the rest isnt going to achieve anything.
    CTWUG - MWEB uncapped - 2500K - Dual Xeon E5320 - N40L
  8. #8
    Default
    Quote Originally Posted by Drunkard #1 View Post
    Jaa this is right . normally blue with the white mate they will be twisted together .
    If it walks like a duck and kwaks like a duck ..its a duck
  9. #9
    Default
    I also live in a complex. What I did was order the line first, then when the line was up I ordered the ADSL self install. Didn't cost me a cent.
    Can't be much different from your scenario. We have a Telkom cabinet (blue and green box) at the entrance to the complex. Then each house is pre-wired, the wires are hidden behind a blanking plate.
    Intel 486 DX2 66MHz
    16MB RAM (4x4MB)
    Tseng 4000 1MB 256
    512MB HDD
    Creative Sound Blaster 16
    Creative Quad Speed CD-ROM
    14" Tatung VGA 800x600
    Windows 95
  10. #10
    Default
    Thanks for all the replies guys. When I went to Telkom direct on Friday they said that they will still have to charge me the installation fee as the line has to be activated. I therefore have given up of connecting the point myself as they will do it as part of the installation.
    To avoid the cost I chose the Closer 1 option and will just downgrade to a normal analogue line after 1 month. That saved me R500 and odd.
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
