Results 1 to 8 of 8
Thread: DIY Home alarm system(s)
  1. #1
    Question DIY Home alarm system(s)
    Advice needed on DIY systems. Best places to buy from, good prices etc.
    Sure, there are previous posts about this, but they seem a little dated.
    I'm looking for an easy to install system with 3 - 4 PIR's, some door/window guards, modular. Reasonably priced!
    From what i've seen wireless is the way to go.
    websites ?
    shops ?
  2. #2
    Default
    The Yale security shops are pretty good to go look at and find what you want or similar.
    However I would check around for pricing before buying as they are not that cheap.
  3. #3
    Default
    I bought a paradox system from www.s4s.co.za
    Excellent service from them always. The paradox system does cost a bit more though and I went for the USB attachment too where you can just connect it up to your pc and program it from there. You can program it without a pc but it involves going through lots of menus on the keypad or looking in the book and typing in codes.
  4. #4
    Default
    Quote Originally Posted by rorz0r View Post
    Thx, will take a squiz
  5. #5
    Super Grandmaster ToxicBunny's Avatar
    Join Date
    Apr 2006
    Crimetown
    Posts
    47,837
    Default
    I will be buying stuff from s4s soon enough probably.. going to redo the entire alarm in my house.... gonna go wireless I think, even though it costs more.
    The other shop to look at is : http://www.thediyshop.co.za/ they also sell paradox stuff and have some decent prices.
  6. #6
    Default
    Not kidding about the prices!
    Mhhh Vertical Curtain Beam?
  7. #7
  8. #8
    Default
    bookmarked for later, thx
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
