Facebook   Twitter    YouTube    RSS Feed    Android App    iPhone and iPad App     BlackBerry App
Subscribe to Newsletter
Results 1 to 12 of 12
Thread: Connecting front panel usb 3.0 to motherboard
  1. #1
    MSI Notebook Rep cerebus's Avatar
    Join Date
    Nov 2007
    Somerset West
    Posts
    19,788
    Default Connecting front panel usb 3.0 to motherboard
    My new Haf case has a front panel with 2 usb 3.0 ports, which have cables to attach onto the motherboard. Only problem is I have no idea how to get them on there. What sort of adapter should I be looking for? I've seen usb3 to 20-pin adapters but my board has no 20-pin on it.
    Any help?
  2. #2
    King of de Jungle Garyvdh's Avatar
    Join Date
    Mar 2005
    District 9
    Posts
    77,666
    Blog Entries
    21
    Default
    Which motherboard do you have?
  3. #3
  4. #4
    Grandmaster Reaper84's Avatar
    Join Date
    Jun 2008
    Port Elizabeth
    Posts
    2,606
    Default
    There is an adapter that plugs into the 20 pin connector from the case and ends with 2 usb ports on the other end. Those will need to be routed probably through the water cooling holes at the back of the case to the back USB3 prts on the motherboard.
    Link
    Not very tidy but what can you do
  5. #5
    Super Grandmaster
    Join Date
    Feb 2009
    Stellenbosch
    Posts
    8,047
    Blog Entries
    1
    Default
    Your motherboard does not have USB 3, so you cannot magically make USB 2 into USB 3
    Unfortunately I have no idea on what you can do to connect the USB 3 front panel connectors as USB 2 ports on your motherboard.
  6. #6
    Super Grandmaster
    Join Date
    Jun 2009
    Snorries
    Posts
    10,477
    Default
    Quote Originally Posted by Pada View Post
    I got a USB3-USB2 cable with my Asus motherboard (or my Corsair case, I'm not sure), so I could plug my front panel USB3 ports into either a USB3 port via the attached cable or use the adapter and connect it to USB2 ports.
    The cable will look like this: http://www.rebeltech.co.za/index.php...oducts_id=4482
    Here's one: http://images.pugetsystems.com/pic_d...t=200&id=19690
    Just look for a store that sells those cables.
    Quote Originally Posted by Rickster View Post
    Why is everyone going ape **** over this car, it looks like junk and the performance must be too.
    Quote Originally Posted by KSINGH View Post
    Oh no you didn't
  7. #7
    Join Date
    Jun 2008
    Port Elizabeth
    Posts
    2,606
    Default
    Ah. You dont have USB 3. That make a difference
    Have a look at these but you'll only get 2..0 speeds
    Try get a USB 3.0 pcie 1 x expansion card and then connect them to that?
  8. #8
    Join Date
    Nov 2007
    Somerset West
    Posts
    19,788
    Default
    Quote Originally Posted by Reaper84 View Post
    I can live with usb2 speeds... but where does that cable connect to on the board?
  9. #9
    Super Grandmaster
    Join Date
    Feb 2009
    Stellenbosch
    Posts
    8,047
    Blog Entries
    1
    Default
    Thanks froot.
    After I read this thread, I noticed that my MSI X58A-GD65 motherboard doesn't have USB 3 headers either, even though it includes 2x USB 3.0 at the back!
  10. #10
    Default
    I've been looking for someone who stocks a USB 3.0 pci-e card with one of those headers for a while now, but my efforts have been futile.
    I have an Asus P8P67-M Pro motherboard, which has lots of PCI-e slots, but no USB 3.0 headers.
    If someone sold one of those USB 3.0 PCI-e cards with headers and not one with ports that come out the back, I would definitely buy one.
  11. #11
    Join Date
    Nov 2007
    Somerset West
    Posts
    19,788
    Default
    Quote Originally Posted by ashfaak View Post
    Ai. so nothing then.
    This is the item.
  12. #12
    Default
    I have hit this exact same issue... The CM adapter looks nifty. Thanx for the info guys!
    i7 2600K @3.8 | GA Z68P-DS3 | OCZ Vertex 4 256gb SSD | 16gb HyperX Red | GTX670 Windforce | Antec H2O 920 | CM 600W Silent Pro M | CM HAF 922 | 27" IPS WQHD
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
