Facebook   Twitter    e-mail newsletter    YouTube    RSS Feed    Android App    iPhone and iPad App     BlackBerry App
Results 1 to 11 of 11
Thread: Bad creaking noise when opening/closing passenger door
  1. #1
    Default Bad creaking noise when opening/closing passenger door
    Hello everyone,
    Wonder if myb can help with this one. My mazda etude was in a left-side smash a few years ago. Now the passenger door is making a bad creaking noise when opening/closing. It happens at each lock on the door travel. I suspect it's that black joining arm between the 2 hinges. I've sprayed q20 but the noise is still there. Anybody had any experience like this or know what this joining arm is called or what could be causing this noise?
  2. #2
    Default
    Could be that the door is out of alignment with the hinges, and you therefore hear the metal on metal screeching.
    Samsung Galaxy S+
    Samsung Galaxy SII (Black)
    Samsung Galaxy SII (White)
    Samsung Galaxy Note II (Grey)
  3. #3
    Master werny's Avatar
    Join Date
    Nov 2009
    Bellville, Cape Town
    Posts
    780
    Default
    Had same problem with my TATA (very ashamed of it ), I then saw that the one screw weren't tightened good enough in the door and was making the noise whenever I open or close the door.
    Just look around for some loose screws or bolts.
    "It's like lifting up the queens skirt and then finding out she's wearing a thong" - Jeremy Clarkson
  4. #4
    Default
    Will look around. Can anyone recommend someone in Durban that I can take it to?
  5. #5
    Default
    Q20 is also the wrong thing for that, you get a white lithium grease stick at most parts shops.
  6. #6
    Super Grandmaster Fazda's Avatar
    Join Date
    Apr 2009
    Why not Zambia?
    Posts
    7,606
    Blog Entries
    13
    Default
    Have you sprayed the hinge itself?
    Not the black arm~ that shouldn't cause the creak.
    The hinges can also loosen up and then the door will drop.
    If Q20 on the hinges doesn't work, just stop at a panel beater - any panel beater, and ask them to have a look ~ those guys work with this sort of thing every day.
  7. #7
    Default
    Quote Originally Posted by Beachless View Post
    Good for troubleshooting though.
  8. #8
    Default
    Yup sprayed the hinges with Q20. Will check if they're loose and spray them again tonight. The door lines up straight though.
  9. #9
    Join Date
    Apr 2009
    Why not Zambia?
    Posts
    7,606
    Blog Entries
    13
    Default
    Quote Originally Posted by peeryus View Post
    OK, then pop into a panel beater - someone will have to physically look at the door first.
  10. #10
    Default
    Quote Originally Posted by AstroTurf View Post
    Mineral oil is not good for plastic though and he mentioned a black joining arm.
  11. #11
    Default
    Got it sorted guys. Took it to a panelbeater. Seems there was just a bolt missing. Guy just fitted it on while I waited and it's good as new.
    Thanks Benroe Panelbeaters!
Similar Threads
  1. Garage door opening size
    By jacqvt in forum Off Topic
    Last Post: 31-03-2012, 09:21 PM
  2. Wispeco Lux-A-Door garage door manual/advice?
    By ponder in forum Health, Wealth, Leisure and Relationships
    Last Post: 14-08-2011, 05:47 PM
  3. Replies: 6
    Last Post: 26-01-2011, 02:44 PM
  4. Article: High Court is 'creaking to a halt' - Judge Satchwell
    By jes in forum News and Current Affairs
    Last Post: 09-11-2010, 01:03 PM
  5. Door to door market research - AARGH!
    By Flanders in forum Off Topic
    Last Post: 13-08-2009, 02:56 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
