Facebook   Twitter    e-mail newsletter    YouTube    RSS Feed    Android App    iPhone and iPad App     BlackBerry App
Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: RAW vs JPEG: How significant is the difference in photo quality?
  1. #16
    Grandmaster Nanfeishen's Avatar
    Join Date
    Apr 2006
    Neither Here Nor There
    Posts
    3,427
    Default
    If your camera allows it, you can always shoot in RAW+ (takes a RAW image plus a jpeg) , then you can work from there and decide, best of both worlds.
    Abandon the search for Truth; settle for a good fantasy.
  2. #17
    Default
    Quote Originally Posted by Nanfeishen View Post
    That would seem like good advice but I know a lot of people look at the jpeg and then ask why the RAW image doesn't "pop" or it looks washed out. The raw image lets you control how the final image is "developed." If you think you may want to do any adjustments or effects to an image then shoot raw otherwise just shoot jpeg.
    Think of it this way. The raw file is a negative. It's needs processing/developing to give you the final product. A out the camera jpeg is like a photo print, to make adjustments means "rescanning" and adjusting, this causes image degradation. This is probably a little over simplified but you understand what I'm getting at? There is a time and place for each.
    Why yes, my one eye is bigger than the other. Thanks for pointing that out.
  3. #18
    Default
    Quote Originally Posted by ldmelsa View Post
    That's not true. And it does not even matter to photography.
    It is true.
    Define photography. It sounds like your definition is pressing the button...
  4. #19
    Default
    Quote Originally Posted by chrisc4290 View Post
    some of the girls didn't wear shoes to school, so he had to copy and paste that.
    SIDEBAR / While technically trivial, I'd never make this type of mod ... such a pity to alter reality in a shot specifically aimed at preserving memories. Shoeless at school is a great memory 30 years later, now erased. Pity. Tell your friend we object.
  5. #20
    Master
    Join Date
    May 2011
    /\¯¯/¯¯¯\ⁿ-
    Posts
    874
    Default
    Quote Originally Posted by Arthur View Post
    i could not agree with you more.
    [i5 3550|asrock extreme4|4*2GB corsair platinum 1333|2*GTX285|corsair force3 120GB|2*samsung t260|logitech mx1100 + wave|antec signature 850w|antec 900]
  6. #21
    Default
    Friend is a professional photographer and uses a Nikon with a 45mp body.
    Maybe he is using one one these babies : http://www.hasselblad.co.uk/promotions/h4d-launch.aspx :P
  7. #22
    Default
    Quote Originally Posted by DylanS View Post
    To shoot school photos? I doubt it...
  8. #23
    Default
    Quote Originally Posted by BigAl-sa View Post
    It is true.
    To me it sounds like he advocating getting things right in camera - iow everything up to and including the pressing of the button.
    Most people equate RAW with the digital darkroom but realistically, how many film photographers do you know who have even set foot inside a real darkroom let alone processed their own negatives because the majority of the ones I knew of would send their film off to the lab, unless they shot B&W.
    "Le mieux est l'ennemi du bien." FM Arouet
    "All that is necessary for the triumph of evil is for good men to do nothing." Edmund Burke
    "Never argue with an idiot. They drag you down to their level, then beat you with experience" Unknown
  9. #24
    Default
    Quote Originally Posted by Quantum Theory View Post
    I know I just thought I would throw it in the mix
  10. #25
    Default
    Quote Originally Posted by bwana View Post
    I would not be able to do what I do without RAW... Not because I don't get it right in camera, but because I shoot scenes with a dynamic range that is impossible to get right in camera. Depends what you do. If you've got the storage space and you are not shooting 1000's of images at a time, there is no reason not to shoot RAW and have full control over the JPEG conversion.
  11. #26
    Super Grandmaster
    Join Date
    Jul 2007
    Durban
    Posts
    9,129
    Default
    They will both produce the same quality.
    Nope. One is a 25 Mb file, one is a 3 Mb file. There is a definite difference in quality.
  12. #27
    Super Grandmaster BeVonk!'s Avatar
    Join Date
    May 2006
    Posts
    7,688
    Default
    Way I see it: You either process the raw photo data yourself afterwards (RAW) - or you let the Canon/Nikon/etc software on the processor in the camera do it for you and spit out the resulting jpeg. Big competition between manufacturers on who can make the best software/chip to produce the best processed jpeg.
  13. #28
    Junior Member
    Join Date
    Nov 2007
    Melkbosstrand; CT
    Posts
    7
    Default
    May be a bit late to jump on the wagon here, but here goes anyway. Unless you plan on doing a lot of post processing and manipulation, shooting in Jpeg will be fine. Your ZS8 gives you 14mp which should be more than enough for most photos.
    If you want to start playing with stuff like HDR etc, it might get worth to invest in a camera that shoots in RAW too. But with that comes an investment in software like Lightroom and an investment in time to learn how to use RAW properly.
    But if you are planning on shooting family photos, party shots, your pets etc etc, jpeg would be more than adequate to do the job. Rather make sure you know learn how the use the camera in Manual mode before you worry about RAW.
    As Chase Jarvis said, the best camera in the world is the one you have in your hands right now, so go out and shoot!
    PS. For the record, I shoot in RAW+Jpeg
Similar Threads
  1. animated gif/jpeg maker
    By Luigiv in forum Apple Mac, iPad and iPhone
    Last Post: 29-01-2012, 04:03 AM
  2. JPEG optimisation?
    By SlinkyMike in forum Photography
    Last Post: 16-01-2010, 10:44 AM
  3. raw v jpeg
    By simonbee in forum Photography
    Last Post: 23-11-2009, 10:22 PM
  4. Photo quality of a sub R1k phone
    By Rouxenator in forum Cellular: Mobile Phones, Call Contracts, Content, MMS and SMS
    Last Post: 30-09-2008, 04:04 PM
  5. Jpeg, png, gif, bmp
    By Debbie in forum PC Hardware and Gadgets
    Last Post: 16-10-2007, 01:53 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
