Hi alltogether,
I use a Huawei E620 (ID: 12d1:1001) and monitor the signal quality with xfce4-cellmodem-plugin (also tried comgt & minicom). Everytime I close the application (connected to /dev/ttyUSB2) the pppd dies.
The PPP daemon has died: A modem hung up the phone (exit code = 16)
With enabled syslog debugging:Used drivers:Code:Mar 26 22:00:25 [pppd] Script /etc/ppp/ip-up started (pid 24146) Mar 26 22:00:26 [pppd] rcvd [IPCP ConfReq id=0x28] --> pppd dies Mar 26 22:00:26 [pppd] Connect time 0.1 minutes. Mar 26 22:00:26 [pppd] Sent 0 bytes, received 4 bytes. Mar 26 22:00:26 [pppd] sent [IPCP ConfReq id=0x5 <compress VJ 0f 01> <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>] Mar 26 22:00:26 [pppd] sent [IPCP ConfNak id=0x28 <addr 0.0.0.0>] Mar 26 22:00:26 [pppd] Modem hangup Mar 26 22:00:26 [pppd] Connection terminated. Mar 26 22:00:26 [pppd] Waiting for 1 child processes... Mar 26 22:00:26 [pppd] script /etc/ppp/ip-up, pid 24146 Mar 26 22:00:31 [pppd] sending SIGTERM to process 24146 Mar 26 22:00:31 [pppd] Exit. --> Automatic wvdial redial Mar 26 22:00:42 [pppd] pppd 2.4.4 started by tobias, uid 1000 Mar 26 22:00:42 [pppd] using channel 21 Mar 26 22:00:42 [pppd] Using interface ppp0 Mar 26 22:00:42 [pppd] Connect: ppp0 <--> /dev/ttyUSB0
2.6.19-gentoo-r5
> CONFIG_USB_SERIAL=y
> CONFIG_USB_SERIAL_OPTION=y
I don't have a clue what causes the interfere of ttyUSB0 and ttyUSB2. Maybe you have.
Inte
I'm already in contact with the xfce4-cellmodem dev and he also has no clue what the reason is.
Bookmarks
