Facebook   Twitter    YouTube    RSS Feed    Android App    iPhone and iPad App     BlackBerry App
Subscribe to Newsletter
Results 1 to 9 of 9
Thread: I have a couple of questions?
  1. #1
    Default I have a couple of questions?
    Im not to clued up with all this pc stuff so please bear with me...
    1- How much wuld i spend on a AM2 duel core ?
    2- wuld it work on a geforce 6100 M9 biostar MB?
    3-how does am2 duelcore compare to core2duo?
    4-Are HD monitors out yet if so where and how much?
  2. #2
    Default
    1 - All depends on the CPU that you buy. Prices differ for different CPUs. An AMD 3800+ should set you back about R660, whilst an AMD 5200+ would set you back around R1,900.
    2 - No it won't. The GeForce 6100 M9 is developed for socket 939, not socket AM2. You can see it's specs at http://www.biostar.com.tw/products/m...%206100-M9
    3 - They are considered by many to be less powerful than the Core 2 Duo CPUs. It all comes down to personal preference, really.
    4 - Define HD. Which resolution would you consider HD?
  3. #3
    Super Grandmaster supersunbird's Avatar
    Join Date
    Oct 2005
    Garsfontein, Pretoria
    Posts
    19,518
    Default
    1 - what beanie said
    2 - I have 2 x Biostar 6100 M9 and they are socket 939, there is a GeForce 6100 AM2 and they sell for around R550 to R600
    3 - Core2Duo is more overclockable to a higher range, a 5000+ (2.6GHz) AMD compares to the 6400 (2,13GHz) Intel. But your cant get Dual Core as a cheaper price on a nice motherboard like with AMD, and a low speed AMD should be able decently enough too.
    4 - I'd think most monitors, CRTs and LCD (depending on their native resolution), can do HD resolutions...
    Boycott MWEB
    1. Leave MWeb! They WILL throttle your 1Mbps line to death as soon you download over 100GB
    2. Cancellation form
  4. #4
    Default More Q's
    Ok i think im geting this so
    1-how meny Ghz is 38OO and 52OO exatly? 2-And if i got 38OO would i be ready for DX10 games?
    3-is it worth changing what i have now to dualcore?
    4-Do you get bluRay HD dvd writers yet? if so where can i get one and how much?
  5. #5
    Default
    1 - The 3800+ runs at 2.0GHz and the 5200+ runs at 2.6GHz.
    2 - Not really, it will demand far more processing power than the 3800+ is able to give. A 5200+ would be more able to cope.
    3 - It won't do you any harm. Since I deduce that you are planning to play games, then it is absolutely worth it.
    4 - I am sure they are available, however they are still quite expensive. The "LG GBW-H10N , beige , Blu-Ray (2x) , 25/17/8.5/4.7GB : BD-RE , B" is R6496.70 (inc VAT) from The Prophecy Shop (http://www.prophecy.co.za). Shop around, you ought to find one cheaper somewhere.
  6. #6
    Super Grandmaster
    Join Date
    May 2006
    Rondebosch
    Posts
    7,622
    Default
    1.Athlon X2 3800+ = 2Ghz, Athlon X2 5200+ = 2.6Ghz
    2.Yes, they will be fine for dx10 games, a C2D will be better, but its mainly the graphics card that counts, although the Nv 8800's are CPU intensive so C2D would be better.
    3.What is your current setup?
    4. R7k
    DAMMIT - beanie beat me to it
  7. #7
    Join Date
    Oct 2005
    Posts
    19,518
    Default
    Quote Originally Posted by Project X View Post
    1 - 3600+, 2GHz, 2x 256k L2 cache R900
    3800+, 2GHz, 2x 512k L2 cache R1050
    4000+, 2.1GHz, 2x 512k L2 cache
    4200+, 2.2GHz, 2x 512k L2 cache
    4400+, 2.3GHz, 2x 512k L2 cache
    4600+, 2.4GHz, 2x 512k L2 cache
    4800+, 2.5GHz, 2x 512k L2 cache
    5000+, 2.6GHz, 2x 512k L2 cache R1950
    5200+, 2.6GHz, 2x 1Mb L2 cache R2000
    5400+, 2.8GHz, 2x 512k L2 cache
    5600+, 2.8GHz, 2x 1Mb L2 cache
    6000+, 3GHz, 2x 1Mb L2 cache
    2 - The processor has nothing to do with DX10, it all depends on the graphics card, and only one graphics card supports it currently, the 8800 series...
    3 - What do you have now?
    4 - R5400
    Pioneer BDR-101A , beige , Blu-Ray (2x) , 25/17/8.5/4.7GB : BD-RE , BD- R , DL dvd±R , dvd±r/rw ; 8mb buffer for BD , 2mb buffer for DVD
    R5900
    Same as above but in black...
    Boycott MWEB
  8. #8
    Default
    Haha, R500 extra for a different colour!
    It's not as if that piece of plastic costs more in black when they buy it, does it? Anything for profit, it seems.
  9. #9
    Join Date
    Oct 2005
    Posts
    19,518
    Default
    Yeah, I know...
    Boycott MWEB
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
