Facebook   Twitter    YouTube    RSS Feed    Android App    iPhone and iPad App     BlackBerry App
Subscribe to Newsletter
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 27
Thread: A 400 watt sub..
  1. #1
    Question A 400 watt sub..
    How loud is a 400 watt RMS sub. Will it be like slightly having bass, loud, or will it shake the car completely.
    And please note thats RMS, anyone can say they have 10000 watt speakers, meanwhile they 100 watts RMS.
    :: i5 4690K :: Level 10 GT Snow Leopard :: 12GB Corsair :: 10.5TB ::
    :: Sammy 46" :: Radeon 280x :: Win7 :: 10 meg uncapped
  2. #2
    Default
    Quote Originally Posted by 4cer View Post
    400W RMS!
    400W is f@cking loud! It has the ability to make you deaf!
  3. #3
    Default
    It depends on the SPL of the Sub used, as well as the THD of the amplifier used,
    400W RMS could make you deaf if you had 100 SPL speakers,
    but 1000W RMS could sound no louder than a beat box, if you had 82 SPL Speakers...
  4. #4
    Default
    It will depend on your amp! Crap amp, crap sound high powered monoblock can sound reallllly good!!
    What make is it?
  5. #5
    Master
    Join Date
    Aug 2006
    </\PE T☼\/\//\/
    Posts
    658
    Default
    With a sub the box that you use also makes a big difference, it must be tuned to the frequency you want to boost. My box is tuned to 40 hertz but with 400w you could go a bit lower, maybe 35?
    And yes, the amp must be good, a 500w mosfet (cause you can bridge it) is what i would use. That combo will shake the car next you!
    This space is available for advertising. Contact me for pricing.
  6. #6
    Default
    I looked at the title of the thread, and thought "A 400W sub? Damn, if that's how loud the sub is, imagine the dom!"
    Maybe I just have a dirty mind...
  7. #7
    Default
    400w RMS is plenty.
    A good Type D amp (monoblock or bridged) and a proper install will def. rock your car.
    " Has my reputation preceded me? or was I toooooo... quick for it? " -Z.Braniggen
  8. #8
    Senior Member AK65's Avatar
    Join Date
    Jun 2005
    Westville, Debian :)
    Posts
    314
    Default
    and mush your brains too.....
    <shudders>
  9. #9
    Default
    Quote Originally Posted by AK65 View Post
    <shudders>
    Nah I doubt it, it will just be more pure and also if its a 15" the bass will just be much smoother, it will make you wanna turn it up more and more!!!
  10. #10
    Default
    I got a 12" Rockford Fosgate Punch P2 which is 200W RMS, running off a Rockford monoblock and it pounds!
    400W RMS will be plenty to shake the car, provided it's powered by a decent amp. If you're gonna run a 75W RMS amp into the sub then you're probably wasting your time. But if you run upwards of 200W RMS then it'll crank.
    Also depends a lot on the enclosure, how deep it is, it's length, how large the port is etc.
    Procrastination is like masturbation. It may feel good at first, but when you look at the task at hand, you're actually screwing yourself.
  11. #11
    Super Grandmaster dablakmark8's Avatar
    Join Date
    Feb 2005
    CAPETOWN,I have a device,I see telkom/thread killa/neotel.mm
    Posts
    13,953
    Blog Entries
    4
    Default
    bass port must not exceed 80mm raDius
    here is a new members tip
    customwerkz hosted by domaincheap
    I had a dj...dream
  12. #12
    MyBroadband Member arf9999's Avatar
    Join Date
    Jul 2004
    South Africa.
    Posts
    6,792
    Default
    Quote Originally Posted by Claymore View Post
    *sound of sarcastic comment flying over assorted car sound fundis' heads*
  13. #13
    Default
    http://www.pioneerelectronics.com/pn...262748,00.html
    Thats the sub, its a pioneer...
    12" DVC Subwoofer w/Dual 4 ohm or 2 ohm Voice Coils
    1200 Watts Maximum Power
    400 Watts Nominal Power
    89dB Sensitivity
    18Hz
    500Hz IMPP w/Aramid Fiber Composite Cone
    83 Oz. Ferrite Double Stacked Magnet System
    3-Layer Woven Radial Surround 4-Layer
    2.25" Round Copper Voice Coil with PI 180 Voice Coil Wire Projected Pole Yoke with Vented Pole Magnet Cover Single Sided Push Terminals
    For those capped..
    what amp would you guys recommend.
  14. #14
    Default
    how much money do you have
  15. #15
    Default
    Lol.. hmmm.. not too worried about money i can afford that sub easy just dont wanna spend like 5000 on an amp.
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
