You should join our great online community now
Register now
You should subscribe to our free MyBroadband newsletter
Page 14 of 20 FirstFirst ... 41011121314 15161718 ... LastLast
Results 196 to 210 of 286
Thread: Huawei Mobile Connect [HMC], Huawei Mobile Partner [HMP], Huawei E220
  1. #196
    Super Grandmaster AirWolf's Avatar
    Join Date
    Aug 2006
    Port Shepstone, KZN, RSA, EARTH
    Posts
    16,861
    Default
    So what's new in new version of HMP? (I haven't downloaded it yet)
    Hibiscus Coast Photographic Society
    (previously known as: Hibiscus Coast Camera Club)
  2. #197
    Default
    It's installed and working fine. Thanks for all the help Got to agree, a lot more packed into this version, that what I had previously
  3. #198
    Join Date
    Jan 2005
    Jo'burg
    Posts
    212
    Default
    Quote Originally Posted by bwanadave View Post
    I am not even using the E 220 yet - won't be in South Africa till Sunday. But I thought, hey! I can download the big update file here in the US on my desktop MAC, dub it to a CD, bring it with me and use it when I get there.
    What I had was an 8.1MB MPEG1 file which I ran through Stuffit Expander.
    Now I have a binary file - 8.2MB. Have I just wasted about 20 minutes? Will I have to download the update once again, after I have signed up with Vodacom and DO have a modem hooked up to my MacBook?
    I am noy sure if this file that I have indicated here is for MAC. As far as I know it is for Windows 2000, XP & Vista. I am using it on a HP Pavilion Notebook and it work perfectly. The Mobile_Connect that is included in the zip file let you burn a start-up disk. which you can use to burn a CD and if you insert it, it will automatically install the software for the modem from CD.
    I had a look on Huawei site and can't find any software for MAC.
  4. #199
    Default
    Hi Andre1,
    just for future reference, when I'm updating the modem's flash, is it OK to leave the sim card in, or should I remove it before flashing?
    Thanks again for all the help
  5. #200
    Join Date
    Aug 2006
    Posts
    16,861
    Default
    I don't think either way would make any difference, but I have only done mine with the sim in
  6. #201
    Grandmaster
    Join Date
    May 2007
    Zwartkops, Centurion
    Posts
    1,441
    Default
    After flashing the e220 can you explore the e220 modem. Have a look in the drivers folder it should have a folder for mac I think?
  7. #202
    Join Date
    Jan 2005
    Jo'burg
    Posts
    212
    Default
    Quote Originally Posted by tore567 View Post
    Hi Andre1,
    So far I have left my sim card in a few time and it does install without any problems. When you start to install, a window will appear saying that you must remove the sim. If you feel to be on the save side, remove the sim at this stage and install the new software. I do not know if it will damage the sim card, but rather remove the sim card. I have found that either way it does work. But rather be safe than sorry.
  8. #203
    kingrob
    Guest
    Default
    Any big changes in the new MP? Huawei's download site is awfully s....l....o.....w. :-(
  9. #204
    Join Date
    Aug 2006
    Posts
    16,861
    Default
    Quote Originally Posted by ic View Post
    To be safe rather remove the SIM card from any modem prior to doing a firmware update - at the very least it will prevent the device from being able to communicate with a base-station that might unexpectedly interrupt a firmware update at a critical point.
    PS: Installing HMP using the 'force update' option should not change the firmware of an E220 modem, instead it would only change the iso image on the E220's internal flash drive, firmware is embedded deeper within the device.
    The last time I flashed mine with HMP without the force update option ticked and the software on the flash drive was still changed from HMC to HMP
  10. #205
    Join Date
    Aug 2006
    Posts
    16,861
    Default
    Quote Originally Posted by kingrob View Post
    I'm getting ~20KB/s on 384kbps ADSL.
  11. #206
    Default
    thanks again for all the advice
  12. #207
    Default
    dear all,
    i've tried to download the software update of E220 USB Modem using the posted link but failed.
    i've been trying it for the past whole week and still no change, simply it stops after downloading few bytes.
    i wonder if it is possible to mail me the software.
    i've updated my E220 & now it is looked to Vodafon.
    thanks & awaiting your kind feed back.
  13. #208
    Default
    dear ic,
    im located in Kingdom Of saudi Arabia,
    I know the software update worked with guys here, but unfortunatly I can't contact any of them.
  14. #209
    Default
    dear ic,
    my problem is that i can't download the update.
    if i could get it in another way i'll be thankful.
  15. #210
    Grandmaster
    Join Date
    Apr 2007
    Gordon's Bay(Home), Somerset West(Work)
    Posts
    2,304
    Default
    Quote Originally Posted by jhyousef View Post
    dear ic,
    Try using a Download Manager with the Resume function. Maybe that'll help?
    Has joined the Cell C Revolution... Whoosh!!
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
