Facebook   Twitter    e-mail newsletter    YouTube    RSS Feed    Android App    iPhone and iPad App     BlackBerry App
Results 1 to 7 of 7
Thread: Posts in a section
  1. #1
    Question Posts in a section
    Is it possible to see how many posts you have in a particular section, such as Off Topic, similar to the way you can check how many posts you have in a single thread?
  2. #2
    Super Grandmaster AirWolf's Avatar
    Join Date
    Aug 2006
    Port Shepstone, KZN, RSA, EARTH
    Posts
    12,199
    Default
    Quote Originally Posted by WKJ?:beanie View Post
    I doubt it, but maybe the mods have access to this kind of info
  3. #3
    Default
    I think the closest you could get is going to advanced search, typing in your username, show results as posts, and selecting the sub-forum from the right. Only thing is it shows maximum 500 posts
    Procrastination is like masturbation. It may feel good at first, but when you look at the task at hand, you're actually screwing yourself.
  4. #4
    Spammer be gone bug spray
    Join Date
    Nov 2004
    A nearby event horizon
    Posts
    13,960
    Default
    Yep, there is a pesky 500 search results limit - I expect it is a design feature to minimize database overhead & load.
    There is one way I can think of, I haven't tried it - it should work, although it will be tedious. Do an advanced search for all threads that %username% has posted in, in a set of forums, then add up the number of posts for %username% in each of the search result threads.
    Trolls stab you in the back and bleed you dry like mosquitoes, and that's why I don't feed the BBL trolls with any new posts.
  5. #5
    Master of Messengers teraside's Avatar
    Join Date
    Mar 2006
    Nelspruit
    Posts
    20,136
    Default
    ic, now ic
    Soli Deo Gloria
    Be wise as serpents and harmless as doves,
    |FaithBook|Righteousness|DomainCheap|Gecko Stretch Tents|
  6. #6
  7. #7
    Default
    But thanks anyway, just wondered if it could be done
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
