1.0mbps on usb and 10.0mbps on nic
JET@WORK
Guys during one of my boring weeknights I decided to connect the iburst using the NIC when I discovered the change in the connection speed that is reported by the connection Icon. 1.0mbps on usb and 10.0mbps on nic. Is there really a speed difference between the usb and the nic connection. and can I use the iburst modem to connect to other services other than the wbs network.
Crash
I don't think so hey. I've tested both and I get the same speeds out of both interfaces.
Jongi
I think it means the ethernet port / NIC can do speeds up to 10Mbps. Not that your equipment is doing 10Mbps.
nocilah
Banned
no real speed impact... but i presume ethernet is less cpu intensive and even then probably marginal.
BigJ
In your opinions, which is the better (usb/ lan) to use?
BigJ
I use 2 pcs with a cross over cable. Do I need a hub if I use ethernet or can I use 2 lan cards?
native
If you running on windows then you can have it with 2 n/w cards and do ICS
I think ic had a thread on the setup
lazy to google
BigJ
Nothing like the sweet sound of boxes being turned over looking for cables......
Ta. Ill give it a try quickly. :)
