1200VA Mecer inverter running @ ~190V after loadshedding stops
AlexGouws
Joburg
Hi,
I have a Mecer 720w 1200VA modified sine wave inverter connected to 1x 200ah 12V GEL battery pushing out 20A to the battery.
I've started noticing that once the power is restored after loadshedding the inverter will show an input and output voltage of around 190V (it fluctuates between 190V and 198V) for a while. After about 10-15min it will eventually reach 215V-230V and stay there until the next loadshedding slot.
Is this normal? Should I be worried about this low voltage?
Thanks!
Hi,
Thanks!
modified sine wave can run happily at 176 volts on output ,thats why motors and fans dont usually like them .
weird that the input is also indicated as 196V...
Have you measured it?
Hi,
Thanks!
this device connects output to eskom once it is present
and goes into battery charging mode
voltage dips aren't surprising as the start-up of everything in the neighbourhood is happening
especially with the 4hrs shedding
if you want to avoid this you could switch of the plug that powers the inverter and switch it on x amount of time after power comes on
Thanks I suspect it is from Eskom's side since it happens every time after loadshedding.
As you mentioned it's likely from everything starting up and pulling load causing the dips.
I just wanted to be sure that it won't damage anything.
What voltage level should I be worried about if it dips too low? Sometimes it will stay around 190V for an hour or more and I've seen it go into the 180s.
I don't suppose there is anything I can do from my side since it's likely a grid issue?
180 is pushing it, anything below would be real dangerous
you could ask your supplier if they could change their transformer to a higher tap
Hi,
Thanks!
Blame Eskom
See:
1683469017182-png.1520359
from
I use this on my big inverter for this exact reason.
Lowest I've seen was about 188.
For context, I live in a cottage. My power is fed from the main house AC.
The main house has a solar and inverter system but I am not connected to it, just the regular utility AC.
The main house uses the batteries 90% of the time and I believe it's only set to use the solar panels to charge (might be wrong though).
Is it possible that if the main house batteries are charging from the grid (like at night) that it might cause the voltage drop? I unfortunately can't always access the house to check the inverter's readings...
I also don't know if it might be isolated to our property of if the neighbors have the same issue.
Blame Eskom
See:
from
I have a regular surge protector connected to my inverter (This exact one actually) but it seems to only do overcurrent protection.
Is it worth getting the one you recommend to protect against those voltage drops when the power returns?
If you already have one then I would say not really. All that one I linked does, is wait 5 mins before switching back.
It is more then likely a carry over from the main house
