200mb Fibre for 8 people
Vanilla_Falcon
Hi guys and gals,
I want some insight on this. We live on a small holding, theres 3 houses with a total of 8 people. I am getting a 200mbps Premium Uncapped fibre line installed and then splitting it to all the houses. I would say 6 of the people are heavy internet users (Games, Downloads, Streaming and so on). Will this line be enough?
AdrianH
Hi guys and gals,
100Mb will be ample for 8 people, mind about 200Mb. Buy a router with decent QOS so that you can give priority to streaming etc
WAslayer
Stop stressing about whether it's enough.. split the line according to how much each household contributes towards payment of the connection.. if this is too slow for any given household, they can take out their own connection..
If all three households split the bill equal, that's 66.6666mbps for each..
Then let each household worry about QoS themselves..
DanDango
Hi guys and gals,
Run a pfsense server to balance the user load.
ThatOtherDude
I do bandwidth management on my run of the mill Tenda router, 100mbps FD fibre.., split x ways. Neighbor gets X, tv gets X, laptops get x, the wife gets 1Mbps (just kidding) and I get the rest.
cantankerous
200 Mbps between two of us. Peak will see both of us streaming HD and browsing devices. UniFi Controller is telling me we've averaged 10 Mbps max over the past two weeks. You'll be fine with 200 Mbps.
ld13
Just do not tell the ISP you are doing this - it is against all of the T&Cs I have had my hands on so far. But to answer your question, as already mentioned, it will never be enough. Some form of QOS will be a must, to avoid 1 user pulling the line down with 1 torrent opening 30+ connections.
Netflix e.g. claims to take up to 25mbps with some tests leaning more towards 15mbps. That comes to 15mbps*6 streamers = 90mbps if all of them stream at the same time, thus not leaving much for the rest of the folk. Assuming of course that you do not experience congestion and can sustain a 90mbps stream on your line.
Marcell1992
Netflix does not need 15-25mbps. I'm watching 1080p fine with my 10mb line that is actually maximum 8mbps
ThatOtherDude
I have Netflix UHD but I can't seem to find a single UHD movie/series when I browse...
maybe I'm just a bit "dom".
It would probably help if I actually use the damn service (only the family does)
$m@Rt@$$
You need a UHD capable device for it to show available in UHD. There are loads of UHD content on Netflix.
Tariqe
Different question, I have a Hisense 65U8A streaming on a 50 mbps line connected via an ethernet cable, the tv can display the speed being used, it is never more than 15.25 mbps at 2160, even though Fast.com will show 47 plus mbps, just curious as to via the tv wont register higher than 15.25
BradleyKZN
Is this while running Netlflix or something? Your streaming might only require that much so it wont show higher?
ld13
Ain't you answering your own question? Fast.com is a speed test that attempts to max your line (50mbps) while your TV is simply showing the speed being used (15.25mbps). Netflix can only use so much bandwidth.
Suspect99
4k uses about that much. It doesn't need to use more just because your line is faster
