2020 Toyota HiAce Revealed In Leak, V6 Petrol And Hilux Diesel Options Likely
Ivan Leon
Toyota has been working overtime developing a new 2020 Toyota HiAce (codenamed H30) to replace the current generation, which has been around in its current shape since its launch in 2004.
According to documents seen by CarAdvice and images sent in by a CarAdvice reader, the new HiAce will not only lose its trademark flat front-end, but will also pick up a petrol V6 option, along with the current-generation 1GD 2.8-litre diesel engine from the Toyota HiLux and new gearbox options.
In a bid to increase the safety offering, Toyota is understood to have moved to a body with an elongated front end (similar to the Hyundai iLoad and Renault Trafic), which is aimed to improve its crash rating and increase leg room in the first row.
To accommodate the increase in length, measurements of both the short- and long-wheelbase versions of the HiAce have grown.
Short wheelbase:
  • Length: 4,695mm (old) / 5,265mm (new)
  • Width: 1,695mm (old) / 1,950mm (new)
  • Height: 1,980mm (old) / 1,990mm (new)
  • Weight: From 1,620kg (old) / From 2,150kg (new)
Long wheelbase:
  • Length: 5,380mm (old) / 5,915mm (new)
  • Width: 1,880mm (old) / 1,950mm (new)
  • Height: 2,285mm (old) / 2,280mm (new)
  • Weight: From 1,810kg (old) / From 2,325kg (new)
The HiAce will now be powered by one of two engine options: either a 3.5-litre petrol V6 engine that produces 206kW of power, or a 2.8-litre turbocharged four-cylinder diesel that produces 132kW of power.
The petrol V6 engine was most recently used in the Toyota Landcruiser Prado for the Chinese market. It includes D-4S, combined injection system and dual VVT-i.
Each engine can be optioned with either a six-speed automatic or six-speed manual gearbox.
Depending on the engine, gearbox and body configuration, towing capacities range from 1,400kg (braked) to 1,900kg (braked) and it appears Toyota is aiming for a leading safety rating with the inclusion of side and knee airbags across the entire range.
While the HiAce represents only a small portion of sales for Toyota in Australia (just under 7000 units in 2018, compared to over 200,000 total sales), it commands a 34 per cent market share and regularly outsells the Hyundai iLoad.
We have reached out to Toyota for comment, but they're not ready to hand over the goods just yet.
"At this stage, we’re not in a position to provide any further details," said Brodie Bott, Toyota Australia manager, public affairs.
https://www.caradvice.com.au/726744...ak-v6-petrol-and-hilux-diesel-options-likely/
genetic
Brilliant idea, a taxi with 200kw. Wtf not Toyota. Hopefully SA gets a detuned 90kw version.
The top end model gets 200kW. Taxi's will be using the base model like all their current Hi-Ace's.
gamer16
Am I the only one that noticed a lack of sliding doors for the back?
eg2505
new toyota hiace, running reds and killing Peds near you.
all its missing is the SA additions, SA flag decals and ac schintzer stickers.
voldoverse
well probably never see this version, theill just keep building the current model cheaply locally and sell it for this new ones price.
quantum vivo if you will
