2Kva 1600w Mecer IVR Alternative Inverter With Adjustable Voltage Parameters
DuracellBunny
Close To Fking Up Energiser
Because of the amount of come backs I have been getting on the Mecer inverters which lead me to look for an alternative and I stumbled across this gem and with voltage settings being adjustable being an absolute bonus. There are 2 variations that I have received in stock. One that comes with a Solar charger controller and the other without it.
Spec Sheet
I have tested the unit over the weekend and it works like a charm, Slight buzz on battery mode same as the mecer units. I have them bundled up together with the battery box and AGM batteries 2 X 100ah. Unfortunately with this current shortage with lithium and pricing being shot through the roof is insane, we have decided to offer them with leads for the time being till lithium pricing does get better
The Option with the SCC is a PWM controller - 60V Max PV Voltage - 50A Max Amps
7 units available for the one with no Solar charger controller.
4 units available with the unit with the Solar charge controller.
I am expecting to receive 5 more of the unit with the SCC and 10 more on the unit with no SCC by next week Monday. There after more stock will only be in the new year.
Inverter and batteries come with a 2 year warranty. You are most welcome to pm either myself or @ADrunkTeddyBear for a system
Price range we looking at for future? (Solo and/or with trolly)
Or is it a state secret? :D
If a secret just PM me the price, know someone that's looking.
SRNE 3kw inverter with 4000W mppt - R7999
Took it out of the box to play around with it
Stock update 4 available on the Non SCC version.
200Ah Batteries available also on bundle with the Non SCC version.
Linkqnet 2Kva 1600w & 2 X 200ah Gel Batts @ R 14999 (Only 3 Bundles Available)
Stock update for those that haven't got themselves setup for Christmas and New years loadshedding or just looking to upgrade.
4 Left Available of the Linkqnet 2Kva 1600w Inverter no solar controller (Cut of voltage settable) @ R 3399.90
8 left of the GPB 12.8V 100Ah LIFEPO4 Battery @ R 8899,90 (Supplier increased pricing)
1 Left of the SRNE 3kw inverter with 4000W MPPT Controller - R7999 (More stock expected Jan or Feb)
The above can be bundled with a battery box for a trolley kit.
Stock update and a Happy New Year to you guys and gals.
3 X Available of the Linkqnet 2Kva 1600w Inverter no solar controller (Cut of voltage settable) @ R 2999.90
2 X Available - Linkqnet 3Kva 3000w Hybrid Off Grid Inverter @ R 7699.90 (1 on Reserve)
6 X GPB 12.8V 100Ah LIFEPO4 Battery Arriving this week @ R8899,90 (2 On reserve)
Trolley Kits Also Available
Expecting 50 Hubble Batteries by End of Feb set in stone with Hubble. (This Value can go up depending on my stock need)
Hubble S100A 1.2KwH 100Ah LiFePO4 (First Life Cells) @ R 6999.90
Hubble confirmed going forward the above will be the only option available in 12V that they will be bringing in and all other models are discontinued.
Please PM for those that want to reserve stock.
Edit* Forgot to mention the price above is correct dis no scam. The above is near RRP from Hubble
Howsit
I just PM'd you regarding the Linkqnet 2kva 1600w inverter @ R3k as well as a request for a 12V inverter.
Stock update
1 X Available of the Linkqnet 2Kva 1600w Inverter no solar controller (Cut of voltage settable) @ R 2999.90
1 X Available - FiveStar 3Kva 300w Hybrid Off Grid Inverter @ R 6799.90
4 X GPB 12.8V 100Ah LIFEPO4 Battery @ R8899,90
38 left available on the Hubble Shipment arriving end of Feb
