4liters of water
L1cache
I drink close to 4 liters of water a day......is good or bad for me.
blaaislaai
The recommended liters per day is 2liters, maybe overdoing it a bit. But also depends on your weight/size
atomcrusher
It's good for you, but it has not improved your writing skills .. you forgot the "?" after your question
Thor
Here is a related post on my forum.
Maybe it helps.
Oh and guys, you can all free to join and support it. I had a thread on it earlier made even more exciting changes to it.
Here is a link to the Water Question.
http://muscletalk.co.za/viewtopic.php?t=35
Then also personally in season I consume around 4-5 liters a day.
But then again I weigh about 112kg body fat% around 11-12% atm.
envo
nothing wrong with that amount if you're keeping active as well. takes a lot of water to get water intoxication
LazyLion
King of de Jungle
Sounds like too much, but you need to go to your doctor and have your sugar and sodium levels checked.
Under normal conditions two should be enough.
Compton_effect
A bit over the top. Are you always thirsty?
If so - have yourself tested for diabetes asap.
But drink the water - you only need the pain from one kidney stone to know why. :crying:
