5G speeds on iPhone 13 Pro and Samsung Galaxy S21 compared (on Vodacom)
Dolby
Is slower iPhone not a cleverly designed Apple feature to reduce battery, as well as load on the networks ?
Grep
So pretty much the same? Can only imagine the amount of data that was used.
G.A.S
So let me get that straight ... 450 / 8 * 0.49 = R2.76 per second out of bundle (locally)?
The networks are gonna love you if you dare to roam overseas.
McGuywer
To test the 5G speeds on the two devices, MyBroadband selected a location with good Vodacom 5G coverage.
Try excellent coverage! Then you will see speeds!!! :ROFL:
bwana
MyBroadband
Super Moderator
Yeah, this article got me curious, so I downloaded a speedtest app...
...turned off WiFi...
...and then realised what the hell I was doing.
Last I heard Vodacom and MTN had zero-rated data used for the MyBB speedtest app.
Sapphiron
At these types of speeds latency is far more important.
Apple seems to be lacking on that front.
@Jan, thanks for including the latency numbers as I and other forum members suggested.
How about throwing in a midrange 5G device. See if these house battery priced devices have any advantage on a networking level.
