Thanks guys
Since my original post, I did quite a lot of research and this is what I found:
- Most laptops come with Realtek or similar sound cards...these cards are only stereo. Plugging in a 7.1 surround sound headset won't produce 7.1 channels of sound.
- Most 7.1 headsets use virtual surround sound: They actually only have two drivers (speakers) and try and simulate surround sound.
- The only true 7.1 surround sound setups include an additional sound card, inevitably a plugin-USB type card or has a dedicated 7.1 sound card built into the headset.
Finding true 7.1 surround sound headsets in South Africa is actually very difficult due to poor search options and inadequate product descriptions.
You have two ears, so you only need two earphones. Anything else can be done in software
If you want a *decent* experience, use a pair of headphones with an onboard DAC/AMP with a certified dolby encoder/decoder. I keep these in my bag:
The best RIG yet?
medium.com
The RIG 500 is lightweight and comfortable, the microphone is good, bust most importantly the audio is very good. Not amazing, but good. With some fandangling you can connct the included DAC/AMP to your cellphone with an appropriate USB Type-A dongle. It works great on Android, not so sure about iphone though
My daily drivers however is this combination:
mayflowerelectronics.com
I agree with the audio group that say it is best to have a perfectly neutral DAC and AMP and let the headphones do the colouring. My T50RPs are fantastic for listening to music, movies and playing games. The quiality of the sound is unmatched, and you can pick out the finest detail in lows and highs /simultaniously/. 99% of other headphones I've tried fail to do that
