As per subject my setup is as follows:
8KW Sunysk Inverter paired with x2 Hubble Batteries
Canadian solar panels 455w super high power mono (qty 16)
Would like some advise on following:
Maximum production I have ever reached on my solar production is 15kw(Seems a bit low) this only happened when I moved geyser to solar.
Battery Settings are they correct, my charging amps and discharging amps? would obviously like to protect life span of my batteries but also save on electrical bills as well.
What is maximum I can set Power on System Mode based on my batteries ? Initially had it on 8000 brought it back down to 6500 not sure if its right thing to do.
Any other advise will be appreciated based on my settings attached.
