A bunch of Android info for your guys
DAE_JA_VOO
A bunch of Android info for you guys
I actually wrote this for another forum, but sharing is caring, right? I hope you like it :)
Rooting:
Rooting is essentially the act of giving yourself admin access to your own phone. When you buy an Android phone, you're not exactly the admin of your phone, you're a user. This limits you in a few ways, so you might want to root your phone in order to give yourself FULL access to your device. Once rooted, you can really do whatever you like with the phone. Don't like having to press the power button to wake up your phone? Change it. Little things like that.
One thing to remember, though - rooting voids your warranty. On the other hand, the tech guys at MTN/Vodacom probably don't know a thing about Android OTHER than how to update the software, so I doubt anyone will know anyway.
The upside, however, is that you can just "unroot" if you need to take your phone in, so in the end, you don't really have anything to lose.
Each phone is rooted in a different way, so there isn't a "one-size-fits-all" rooting guide, but here are guides for a couple of phones:
HTC Dream/G1
HTC Tattoo
Nexux One
HTC Desire
SE Xperia X10
Motorola Milestone (Droid)
Those are just a few :)
Before I forget, this first thing I recommend doing once you've rooted, is download and install an app called "ROM Manager" from the market. In this app, do a "Flash Recovery". This installs a recover mod to your memory card, and with this mod, you can flash to different ROMs on the phone itself, with no need for a PC. You can do nandroid backups here too.
ROMs:
A ROM contains the OS that's on your phone. By changing ROMs, you change the Android OS that's on your phone to another one that's either a different version, or has specific apps installed, or is optimized for a certain use, etc. The stock Android version that comes on your phone is made for a vast array of people, so it'll almost certainly include a whole lot of stuff you don't care about. By downloading and installing a custom ROM, you can have what YOU want from your Android phone.
GoldCard
A GoldCard is a modified SDCard which allows you to put the original unbranded ROM on a career branded phone (installing the original HTC Desire ROM on an Orange HTC Desire). Normally, if you try to execute a HTC ROM updater with a Orange phone, you'll be stuck after 4 or 5 clicks on next. With a Goldcard in your phone, you can archive the process.
You can't install a ROM built for an other device just using a GoldCard (installing a Nexus One ROM on a Desire is not possible).
GoldCard is only needed if you have a carrier-branded Desire, even for rooting process. Unbranded phones never need it.
Be sure to keep your GoldCard because it will be needed for each ROM modifications. You can use a GoldCard as a normal SDCard without problem. However, if you create new partitions for app2sd, your GoldCard will ruined.
Functionally :
Create a GoldCard is easy. It will take you 30 minutes. Not all SDCards work to create a GoldCard.
Instructions can be found here
(Took the goldcard section from XDA. I didn't write this part)
Managing an Android phone's bandwidth usage:
The beauty of Android is it's web integration. Google, Facebook and twitter are so closely tied with the phone and that's amazing. The problem, however, is that this EATS bandwidth. And here in SA, Bandwidth = money, lots of money. So what I've done is stop my phone from using bandwidth when I'm on the data connection, but go crazy on the WiFi connection. Since I have WiFi here at home, that works out pretty well for me. So here's what you do. Jump to Settings-> Wifi and networks -> Mobile Networks, and uncheck Enable Always-on. Then, I suggest you create a shortcut on your homescreen somewhere to Settings-> Accounts and Sync so that you can easily disable background data. Furthermore, I would recommend disabling notifications your facebook and twitter apps, and manually update those things. Doing this, you can save yourself a fair bit of cash. On a few occasions, I had enabled my data connetion and within a few minutes, my phone had downloaded 10MB, sometimes even 15MB. That's 30 bucks, and that was probably for facebook profile picture updates.
Recommended apps
For starters, here's a list of apps that I feel are absolutely mandatory for Android users:
SetCPU for Root Users
- This app can be used to govern your CPU. For example, when my phone's screen is off, the CPU is not allowed to go faster than 384Mhz. This save battery power.
Brightness Level
- Another battery saver. You should have your screen's brightness as low as comfortable in order to save battery power. This is a quick switcher for when you need your screen brighter.
Dolphin Browser HD
- Significantly better than the default browser.
LauncherPro Beta
- Replacement launcher, and easily my favourite Android app. Lightning fast, multiple docks, etc. Can't live without it.
APNdroid
3G Watchdog
- Use these two guys together to save yourself from suicide. You can set your phone to disable the data connection once it's gone over XMB.
Extended Controls
- Paid app, but totally worth it.
ASTRO File Manager
- You need a file manager :p
Those apps, in my opinion, are pretty much mandatory for any Android user.
DAE_JA_VOO
Then, the apps that aren't mandatory, but I recommend them:
doubleTwist Player
- Awesome media player that's got a desktop client which allows you to subscribe to podcasts and stuff.
COL Reminder
- I'm very forgetful, so this one is very important :p
Wheres My Droid
- I hate it when I can't find my phone. So now, I send a text from another phone to my phone containing the words "Where's my droid" and it'll ring until I find it. If I text the words "GPS my droid", it replies to the text with GPS coordinates and a link to google maps. Also a great app this.
Network Monitor
- Self explanatory name. Monitor your data and Wi-Fi connections.
AppBrain App Market
Install apps from the web and create lists like this one. VERY cool.
DAE_JA_VOO
twicca BETA
- Without a doubt, the greatest twitter client on the face of the earth. I LOVE this app. All it needs is support for multiple accounts.
Seesmic for Twitter
This is another twitter client, but it supports multiple accounts. I only use this to make quick posts to one of my accounts.
Audioboo
This app essentially allows you to make status updates or tweets in audio format. Very cool.
ShootMe (Screen Grabber)
Screenshot app. Requires root.
FolderOrganizer lite
Also a very important app for me. Tough to explain, but essentially allows you to manage your apps, as well as change their icons. Look at the 4 icons on my home screen, some are apps, some are links, etc:
I'm not sure what more to cover in this post. I think I got around, a fair bit :p Anyway, let the Android chatter begin :D
Hope this helps some of you :) If you have any questions, please don't hesitate to ask :)
Keep well,
Ett
Taqyon
I have another one: IMDB app. Allows you to search movie ratings and watch trailers while you're in the queue at the movies or in the video store. Beats using the web site.
Oh, and Aldiko - bunch of free books, VERY readible on a droid phone.
And! SwiFTP - sets up an FTP server on your phone which you can access from anywhere in the world. Friends can send and download files straight to and from your phone. Permissions allowing of course :)
Ok last one, really - Phonalyzr - Allows you to check how many free minutes and free smses you have left on your contract. Also gives reports in abundance.
Wow! Love it!
Kloon
Best twitter app for Android is without a doubt Twidroyd.
K
kingrob
Guest
Thanks DAE_JA_VOO!!
Now I can't wait to get my grubby paws on a Samsung Galaxy S. :)
francoislr
Awesome info! The Apps list is king!
For games, I want to recommend a few:
Arcade:
Radiant - Awesome retro type Space invader. Beautiful graphics, lots of fun! Never liked the original...this one I almost played through 2 times.
RPG:
Zenonia - Awesome Legend of Zelda style RPG...Lots of fun, lots of weapons and quests. Did not finish it, but very pretty.
Crusade of Destiny - 3D Action/RPG type of game. Looks like WOW, just less intricate, but not bad looking for a phone. A weeks worth of gaming maybe.
Dungeon Hunter - 3D Top view Action/RPG type game. Very pretty to look at, kinda fun to play. Nice to show off the phone with;-)
Puzzle:
Nintaii - Fun puzzle game...just try it!
Bubble Defense 1 & 2 - If you ever played Bloons Tower Defense by NinjaKiwi(Flash Games), this is as good as it gets...You will love these games!
Text Twist Turbo - Lots of word fun...the only reason my girlfriend has not thrown the phone out the window yet:)
Napalm
Anyone know where to get the Filez to R00t my Samsung Galaxy Spica (I5700)
I got Android 2.1 on atm
francoislr
You mean the one at the top? It's built into my ROM :) Another advantage of rooting :) If you're root and don't want to change your ROM, let me know, I'll find the link for you :)
Thanks! Of course I am root;-) DJ Droid as most of us seems to be. What kind of a ROM are yuh runnin?(insert that what kinda macker are you accent to it) Goodness, also trying a few new ROM's on my ancient Tytn 2 for fun...Just installed a 1.6 on it...but I think I need Eclair on it...I just messed up the resolution for a test, easy to fix...but this is just my lab phone for now. Eclair worked okay on it believe it or not.
DAE_JA_VOO
Same :) I'm running the modded one, though, that's got the oldschool apps2sd.
Having some issues with mine though. It runs 10KB/s downloads permanently. I don't know what it's downloading, but it's killing my battery :| I think I'm going to move over to LeeDroid.
cyb3rt
LeeDroid has been good for me so far. I had a weird thing on DJ when downloading a 200mb file over wifi from our FTP server, it went past 100% and just continued for quite a while and then just started freezing the phone, think it was up to 257% when I eventually rebooted... Put Lee Droid on and happy chappy! ;)
