a little help from my friends...
CunderT
hey people
I need a little help with configuring port forwarding on my "Telkom" 5102G Router. If someone could gimme a quick point in the right direction, I would be gratefull. Thanks a million.. :)
Surv0
Make sure your NAT is enabled under interface setup, then click on advanced setup and under that header ull find NAT, there u can input your starting and ending IP address u would like to forward. Alternatively make sure Bridge is selected under interface setup and then you will need to create a broadband connection through windows. When going this route windows configures all your ports and you dont have to actually set up certain ports within the router.
I recommend the latter option...
CunderT
when is it working?
thank you very much, I appreciate your help. I'll be back if this doesnt work... :)
Im actually doing this for BitComet. Is there any way I can test to see if its actually working?
Surv0
I would firstly suggest using UTorrent, much better application. And the only way to test is to just install and attempt to download..
