It's a 400W iSonic...
The cable goes into a molex connector and then continues and ends in another molex connector.
Originally, when everything was running, the fans were attached at the halfway molex connector, and the graphics card was right at the end.
Then when I was shuffling the fans around, I put the fans power at the end and the graphics card in the midway molex connector. Didn't like that for some reason, so I put it back at the end...
The only reason I can think of is that the midway molex connector is slightly loose connectors causing the graphics molex to PCI-E adapter to short the system...
(The molex to PCI-E adapter user two molex plugs...)
The whole system still works fine if I only plug in one of the molex connector for the graphics card, so that's why I think the only reason (as I mentioned above) is that the dodgey connection somehow shorts something.
Both connector are connected to the same copper, so apart from the connection, there is no seal difference...
