Hey Sand_man,
That is awesome. Yeah if i check my SNR and line attenuation this is what i see in the router stats page:
SNR: 6 DB
Line attentuation: 52 DB
So its really not ideal it seems.
Im guessing this is due to no ports available so they probably moved me to the nearest exchange which has open ports, which is probably still way further than where you connected. Ive now tried to trace which exchange im connected to, but the site appears to be down. My number is 011 972 so its definitely not on the same exchange as you.
I have called telkom and they did a port reset so will test again tonight. The main reason for the line was to get Show max vs Dstv, ive given up on Dstv but i cant even stream from Show max on my current line speed.
Hopefully Telkom rolls out full fibre support soon. I know supposedly in Birchleigh / Birch Acres they have Fibre rolled out, but not 100% sure.
Yeah, SNR and line attenuation are poor!
Many factors contribute to a poor performing line, I would harass Telkom into improving it, or at least investigating why it is so poor.
I know Bonaero park is also currently getting fibre so it's definitely 'close'! With Glen Marais being one of the most heavily populated and affluent suburbs in Kempton Park, one would think it would be one of the first areas to get fibre. I don't get why it isn't but yes, surely can't be more than a year away? There's also a massive teachers training college that has just gone up on Dann road. Would suspect their need for high volume, high speed data, to be a priority.
The LTE absolutely kills Showmax and anything else you care to chuck at it! Really is a stellar product. Definitely worth considering if you can source it at a reasonable price. Comes with a 300gb FUP soft cap, more than enough for 85% of users.
But good luck with Telkom/ADSL. They do try sorting out problematic lines but sometimes it requires A LOT of persistence. Just keep logging faults until they escalate and resolve. Took me months of harassing before they found me that magical port...
