ADSL modem and router - same thing ?
Dolby
I know it's a really dumb question, but are they the same thing ?
masticore
no.
A modem is a device that can (typically) establish a connection through a public medium (phone line.)
A router is a device that can direct network traffic to (typically) the traffic's destination.
Be wary of purchasing a "Broadband router". The term "Broadband router" does not mean it includes a modem, it means that a modem can be connected to it and the router can establish the connection through the modem. If you want to purchase an "all-in-one" look for a router that includes a modem.
terencevs
An ADSL Modem/Router is a Router with an integrated ADSL modem. That’s basically it.
bwana
MyBroadband
Super Moderator
An ADSL modem can also be a USB device while a ADSL Router generally connects to the LAN via ethernet or wirelessly.
GangStarr
router has the firmware built in, runs thru your LAN. can have a always on connection
modems run the software off the PC ( which you have to install ) and runs thru USB. connects via broadband connection.
Paul_S
Don't confuse the original poster! :D
A router has absolutely nothing to do with ADSL - if he buys himself a plain Ethernet router he's going to be really pissed off.
Nonsense - the ADSL router/modem combos have the modems built in and are able to handle the connection on their own without the use of a PC.
GangStarr
i was speaking of a straight modem. ( mecer modems and marconi ones)
and I was speaking of ADSL Routers (like the one u have at home :p)
Daniedj
a ADSL modem only has one WAN Port whereas you can normally link 4 PC's on a ADSL Router.
Dolby
wait ... ADSL router and ADSL gateway - the same thing ?
