I currently have a 12v Axpert with 600W PWM charger and 600W of panels connected
I just replaced my Lead Acid Batteries with a Hubble S120 Lithium battery and so far its running nicely.
I use it mainly for load shedding but also the extended outages we seem to have more frequently these days in jhb. I mainly run small loads....TV, router, laptop etc and sometimes a PC or 2.
I would like to upgrade to a second Hubble battery mainly for the extended outages. I would however also love to be able to upgrade my solar but am currently at the limit of the inverter
I have a few choices and would like some advice on the pros and cons of each:
1) I could simply get a second Hubble battery and connect in parallel but I wouldn't be able to upgrade my solar
2) I could get a 3Kva 24 inverter with a 1200-1500 MPPT solar charger. This would allow me to charge the batteries at a higher current from DC (Currently my 1000w only allows 20A) and would allow me to upgrade my solar array. I would have to replace my 12V panels though. I would then connect the 2 Hubble batteries in series. Here I wanted to know the pros and cons of going to a 24v system with batteries in series. I see on the specs for the Hubble batteries I would need a cell balancer if connecting in series. Is this recommended? Where do I get one? How much are they? I tried to find but could only find battery balancers, not cell balancers. How do I connect it to the batteries?
3) Is it possible to get a separate MPPT charge controller with a new set of panels and connect that in parallel with my inverter so both the PWM of the inverter and the MPPT charge controller can both charge the batteries together? So that way the PWM in the inverter can be used to run the load and excess charge batteries and the separate MPPT controller can charge the batteries. Does this work?
Also do you know if Axpert inverters are able to charge from petrol generators? I see the new ones say they they charge from AC or generator power. Not sure about my 1000W 12V.
