Wild Cape
- Feb 3, 2020
Ok I know we have all moved on to better things with lithiums, but I need advice on replacing my elderly folk's
lead acid battery in their Mecer 1000 inverter. Hardly a year ago these were the most popular and common plug
& play inverters available and are still supplied at Builders today. I note there is also an external battery extension connection should we not want to pull the housing apart to install a new battery. I appreciate a Lithium replacement is out the question and probably not compatible given the inverter recharge specs snd settings. There must be hundreds of other folk out there that bought the same Mecer inverter a year or so ago and are now in the same battery predicament ... ?
