Aftermarket Heads Up Displays (HUD)
Rabobi
Been looking at some of the options for my older model Focus to refresh it a bit. There are quite a few options out there to enable a hud on your car. Some use your smartphone and some use a obd connector.
Navdy was the best but the company went belly up. So been looking at the hudway options. They are releasing the Hudway Drive in July so ive pre ordered one. They arent too pricy at around $200. Thoughts?
https://hudway.co/drive
Matt91
Looks nice, although wouldn't you be better off buying something like a newer aftermarket head unit? Would have alot more functionality in terms of display size, music streaming, gps etc. Check out a site called www.seicane.com You can find a really nice head unit that would look like it was factory fitted and for around the same price. Not sure what model Focus you have but here's one for an '04 -'11 Focus at $179.
https://www.seicane.com/2004-2011-ford-focus-2-auto-inch-hd-touchscreen-android-radio-gps-navigation-4g-wifi-usb-obd2-rds-mirror-link-bluetooth-music-steering-wheel-control-backup-camera-s161090
Rabobi
Ive got a mk3 2015 focus. The pre face lift one with the tiny screen
Rabobi
I have the same car. Got this: https://www.seicane.com/2011-2012-2013-ford-focus-touchscreen-android-radio-dvd-gps-navigation-system-with-mirror-link-bluetooth-obd2-dvr-rearview-camera-1080p-3g-wifi-steering-wheel-control-rearview-camera-s32712g
with TPMS and reverse camera. Very happy with the setup.
My daughter took over my 2005 Focus and she wants to get the same setup.
Nice
Looks exactly like the one on the youtube video.
I have also installed a Seicane now. Will upload pics. Its a bit different from yours
rph72
What Launcher are you using? Recently discovered CarWebGuru. Awesome Launcher, although support seem very iffy.
Midnights_Ghost
New layout. Also car launcher pro. Very cool
How much did you pay if you dont mind me asking? It looks sweet.
Is it worth it? I am considering getting one for my Astra but that one has to be bought from Amazon and will cost about R8k to get it here
Rabobi
Its a seicane unit.
My focus had a very outdated display. Was about 4k to my door from their China store.
Well worth it. But takes getting used to
