Air France flight loses an engine over the Atlantic
Everyones-a-Wally
http://www.bbc.com/news/world-europe-41454712
An Air France flight from Paris to Los Angeles was forced to make a sudden diversion when it lost part of an engine over the Atlantic.
One of the four engines on the Airbus 380 flight AF66 failed west of Greenland on Saturday.
No-one was injured in the incident, but passengers remained on board hours after the landing at 15:42 GMT.
The plane was carrying 496 passengers and 24 crew at the time, an Air France spokesperson told AFP news agency.
David Rehmar, a former aircraft mechanic who was a passenger on the fight, told the BBC that based on his observations, the incident was a fan failure.
He said there was a sudden movement followed by a loud noise, which caused panic among the passengers.
"You heard a loud 'boom', and it was the vibration alone that made me think the engine had failed," he said.
Mr Rehmar said that for a few moments, he thought "we were going to go down."
His worry that the aircraft's wing could have been compromised disappeared when the flight stabilised within 30 seconds. And he added that the pilots had quickly shut down the affected engine.
The plane flew for about an hour on three engines before it reached Goose Bay Airport, in Labrador in eastern Canada.
Photos taken by passengers showed the cowling, or engine covering, completely destroyed, and some cosmetic damage to the wing's surface.
Passengers remain stranded on the plane in Canada, as the airport is not equipped to handle an Airbus A380.
Mr Rehmar said passengers had been told two Air France 777s were on the way from Montreal to pick up the passengers.
He said that a bird strike was not a likely cause of the incident at such a high altitude, and his experience led him to believe the stage-one fan - the exterior fan blades on the front of the engine - had somehow failed. But the cause of any such failure is not yet clear.
In a statement, Air France simply confirmed "serious damage" to one engine and said its crew had "handled this serious incident perfectly".
It said passengers were being assisted and it was working to re-route them.
Rick Engebretsen, another passenger, told the BBC: "The crew has been working hard and on the job a long time."
He said they were providing meals and the captain had come out to speak to passengers.
Probably the best aircraft to have that happen in but... Nope!
Interesting flight path to LAX
https://www.flightradar24.com/data/aircraft/f-hpje#f0d2f76
:crylaugh:
Gordon_R
Jings
Treasure Maker
What luck the engine didn't damage the wing, especially when the plane was flying over ocean at the time.
Ockie
Resident Lead Bender
A whole fan/fan bits lying on the bottom of the Atlantic.
Will be interesting to see how they approach this investigation. Without the fan or pieces of it, they wont be able to do fatigue tests on it or look for defects.
FoXtroT
I'm sure they will find some that were sucked into the 2nd stage of the engine.
Ockie
How accurate would assessment of those pieces be though considering damage it might have sustained from being sucked into the engine? The blades after the fan surely would have caused serious damage to the pieces?
FoXtroT
After years of experience from watching Air Crash Investigation I can confidently say that they can figure it out :).
In all seriousness, it's amazing what they are able to figure out from crashed remains so I'm sure they would at least get some sort of understanding from any remaining pieces.
Ockie
True. If I was the investigator I would just be like "This sh*t been through the grinder....literally! Bitch ... what you want me to do with this?" lol
Grant
You do of course realize that the engine is designed and made in America right?
And it probably still works.
It's the flying Citroen's crappy build quality that caused the engine to go flying off.
Ockie
I thought they used Rolls Royce engines?
You have two engine choices on the A380. Either GE or RR. Customer decides. Emirates has been using GE on their A380's since they started receiving them.....but recently switched to RR on new A380's being received from Airbus, so they will have a mix of GE and RR on their A380's.
