Android Phone - determine EDGE/3G and band being used.
T-Man
Hi
On the status bar of the Android phone it indicates EDGE/3G/H. This can also be read via the Android Telephony API.
However, is there a way to (progammatically) determine which band (900/2100/etc) is being used? I can't find anything related in the API. Would some non-API call be able to provide this?
Regards
