Any ideas where to look for my electricity meter?
blunt
So we've bought a new house that is on post-paid electricity. I've found the water meter outside the front gate but am wondering where the electricity meters are usually located? Doesn't seem to be near the water meter.
May seem like a silly question to ask people on the internet I know, just wondering what they look like? Similar to the water meter I guess? Anyone else know where theirs is, outside on the ground under a cover or what?
web
Normally a grey box, do you live in a complex?
MickZA
Some areas have locked street cabinets with multiple meters for the adjacent houses, only the meter reader can access them.
savage
If it is on your property, it will be built into a outside wall, into a plastic box with a removable (slide) cover. Chances are, as others have mentioned, your meter is more than likely locked outside in a street cabinet, only accessible by Eskom / Council.
blunt
It's a free standing house and the only "wall" is a metal fence. I've noticed a grey box on the corner near by, will take a look if it says something eskom related on it. Would've liked to check up on how many units I'm using (I am used to pre-paid :)) but I guess that's probably not an option.
web
there is normally a little flap you can move to the side to watch the meter turn if you are that way inclined.
MickZA
Understandable these days, my postpaid meter is embedded in the outside kitchen wall and easy to read. Maybe pre-paid is an option check with the municipality.
blunt
Indeed I have emailed them but they told me to bring my documentation and go to the municipal offices to find out more.. ain't nobody got time for that :(
savage
You can install a KWH meter in your DB inside your home - nothing stops you from doing so :)
