Anyone using the Antenna Addon? RE: Antenna Performance.
GuRu
Free Electrons
Anyone using the antenna add on have any great increase in speed performance?
1. Using it indoors
2. Using it outdoors
3. Distance from tower
4. Any other ways of using it (ie. on a pole ?) :cool:
Guru I think ur question should Read : "anyone using the antenna add on ?" :p
How would you make one ?
i have been on all the sights regarding wifi/wireless but did not think it would work on this system because of the changing of base stations.
there are a couple of alternatives:
there's a cheap version here:
http://www.mybroadband.co.za/vb/showthread.php?t=17258
look for the parabolic dish... i amde one of those once to sort out frame rate error but realised i was being fooled by wbs technicians to get me off their back, but other have had success and then google the forum cuz i remember there were more and i am too lazy to check.
Tested the UTD in c\o Ouklip and Umfolozi streets in Roodepoort. Without it no signal, with the antenna green 5/5. The Reeds Centurion the same story. Better the signal better the speed
Hey, I just mounted the whole damn modem ontop of my DSTV Dish. 1x Plastic BAG and wholla, 5light connection (from zero) :D
The question was "Anyone using the Antenna Addon? "
Please I need feed back from anyone using the "Antenna Addon" and if it is working for them........ :rolleyes:
The external antennas that WBS are selling aint gonna help you with switching between base-stations bcos they're directional ;).
