Audi A1 - Samsung WhatsApp Calls Not Showing
Zarathustra
Apparently this is a known issue and was hoping that someone figured out a workaround.
Since upgrading from an IPhone to an Samsung Galaxy S20 Note, WhatsApp calls don't show up on the console as they did with the IPhone.
Normal calls work 100%.
Audi is apparently aware of the problem which started with the Galaxy S10. New vehicles work 100%, older vehicles don't work and apparently there is no software upgrade.
Anyone experienced this issue and found a solution?
Gtx Gaming
Gtx Gaming
Does not calls not show up at all, or you can you not answer them?
On ford sync with s20, it shows the call, but you have answer it on the phone :(
