2021 update, Darth Vader not pleased.
I guess time to order replacement pads.
Any local suggestions?
I know which ones I want from amazon. Will post here and find out if anyone want to order with me and then we share import costs maybeNot local but I would look after aftermarket ones, you'll have options wrt material, thickness and softness. Maybe ask for recommendations in the Z Reviews subreddit.
For the headband I can at least do a custom job. The earpads should be perfect.Can buy replacement cups on Amazon. Problem is, the headband will do the same and it's not replaceable.
I would love to get the Dekoni valour pads for my Sony xm3’s, but R1000 is quite steepZMF, Dekoni or HM5 pads, but accessibility and availability I won't be able to say. Just note that replacing the pads will alter the M40x. It best read reviews on the pads as pads aren't simply replacement pads.
There are many brands out there, I won't know, I have never modded nor replaced pads. Even my SHP's seems like brand-new other than the dusty texture in places.
