- May 24, 2010
Common load-shedding battery mistakes to avoid
What you should know before choosing a backup battery.
Do you honestly think that they would recommend anything outside of their catalogue and inventory?Pylontech recommended by both.
Are Lithium batteries compatible with e.g. the Mecer or Ellies 2400VA / 1440W inverters?
Yes, the lead replacement types, but you only get 80% capacity because it doesn't charge to 14.4V (28.8V) which is actually a good thing, will make it last longer.Are Lithium batteries compatible with e.g. the Mecer or Ellies 2400VA / 1440W inverters?
no, not all.Are Lithium batteries compatible with e.g. the Mecer or Ellies 2400VA / 1440W inverters?
If you consider the battery in isolation sure. However, its not as simple as that as each system requirement and configuration may differ.Cost of lead acid is never going to be worth it anymore, once factoring in DoD, twice as much lead acid is required.
For that price, you can get an easy 25KW of battery and an 8KW inverter.There's a guy in my complex who spent ~R150k on an inverter and batteries. Yesterday, JHB Water cut through the Eskom line whilst repairing a water pipe so we've been without either since then. Wealthy bastard spent all that money only to have no power after 6 or 7 hours.
Petrol Generator for the win.
I edited my post.
AGM is lead acid.And no mention of AGM?
Or was running aircons and whatnot for 6 hours.R150k on an inverter and batteries and it didn't last 6 hours? I call BS or he was completely ripped off.
