Bandwidth monitor
adsl3g
Can anyone see their bandwidth usage? Mine displays but says 'N/A" at all the totals.
Ekhaatvensters
No, now we should listen to Telkom and download life. It cant be bigger than 3 gigs so I might get a few lives just in case...
GRES
Uploaded: -21.72MB
Downloaded: -211.88MB
Combined Total: -233.59MB
Remaining: 3.23GB
Regards,
WBS Helpdesk
Very nice from iBurst!
Ekhaatvensters
If only they were carrying bandwidth over.. how else would you get negative cap? Oh yes, of course, with useless service and constant screw ups from WBS, how else.
seburn
Maybe a bandwidth carry over Gres as Ekhaatvenster said? Would that be correct figures ... that would definately be a step in the right direction
MrH
Better not to have a carryover as that could also work in the reverse, like using up 2 months BW in one month and then sitting without any the following month.
Ekhaatvensters
Nah they wouldn't let you use up more than 3gigs or your cap size in one month... thats really stupid. Carry overs on cap could work, but shurley they wouldn't just implement that without any warning? I would like it though, especially if you had a holiday and could then use the one months bandwidth during the next month.
Seriously doubt that this is the case though, theyre having problems with the page, its probably just a screw up.
fishfly
I also had that bandwidth but mine reflected that I had -2gigs
totaled to 5gig usage?
now it just shows N/A :(
TrueTenacity
well if it's on N/A for remaining... just download till they manage to fix it... not like they can trace your usage at the moment....
lman
Do we know that? I thought that all we know is that the bandwidth status page doesn't tell us the bandwidth status. I don't see how this proves that the back-end isn't (a) still counting traffic and (b) standing by to apply the after-cap limit when the time comes.
BigJ
looks like they somehow keeping track.
Uploaded: 131.79MB
Downloaded: 1.05GB
Combined Total: 1.18GB
Remaining: 1.82GB
My DU meter is pretty close, so be careful....:cool:
DU Meter Monthly Report
Period (Month) Download Upload Both Directions
November 2005 1,053,211 KB 136,481 KB 1,189,692 KB
Crash
/me does a little dance on the table.
Pulled down 1.4Gb last night. It's not shown on my Bandwidth Monitor...... WOHOO.
Rocking.
I.E DUmeter says 1.6Gb, but BW Monitor says 396mb.
BigJ
My luck! Just checked usage on website and its spot on.:mad:
grumble,*^$#@*, grumble, moan,@*$#@,grumble
Therefore made a slight adjustment to my sig.
Ekhaatvensters
Crash, are you shure it just hasn't updated yet? Mine can take days to reflect usage...
Mine shows 758mb now... hmm sounds rightish, but might not be totally up to date.
native
Rocking.
Not sure, but isnt WBS Bandwidth Monitor session based?
Not sure how it works if you are on the i-Go pacakge?
regardtv
was supposed to be session based.....
one of my customers has however done >6GB and it's still reflected as 3GB avail... things just don't seem consistent atm the moment...
