Ok so I have fibre with Vumatel and Cell C as ISP. The Vumatel ONT is installed in my office. Cell C connected their CPE (Huawei 8351 router) to the ONT. When I hook up my PC directly to the CellC CPE I get fast internet connection.
However I have Asus DSL-A68U ADSL router than I want to use as the main router/switch. Because control. So I need to have this setup:
[ONT Port 1] <--> [CellC CPE] <--> [Asus LAN port 1] <--> [My LAN]
Thus I tried to connect from Asus LAN port 1 to CellC CPE port and set up the Asus LAN port 1 as WAN port. But then I simply cannot get internet connection. The network connectivity on the asus says that the ISP's DHCP service is not working. I woud llike the ASUS to provide the DHCP is possible. I see the internet connection params on asus to Assign IP. nothing. I tried PPPoE, but then I have to fill in user/pass and I dont know what is is.
I read somewhere that you have to have CAT6 between CPE and router and ONT. Dunno if that is true as I only have CAT5.
My knowledge is limited and I would greatly appreciate help.
