Belkin Wireless
StoneD0g
Hey everyone
I'm not sure If anyone else has ever had this issue, but I really need some help. I have 512k DSL at home, and have had for some time, however my router was in a different building than where my room was. So my computer has always been in this outside building wired up to the DSL. Recently I decided to move my PC to my room and connect to the DSL via a wireless LAN. So I went out and bought a Belkin Wireless Pre-N router and 3 network cards. When I got the network cards I realised that they were simply laptop PCMCIA cards plugging into PCI bridging cards, which seemed very strange. So I plugged my DSL router into the wireless router and set it to act as an access point. I set up my PC in the other house and connected the wireless card. When I booted up my PC I installed the wireless card successfully, the connection was fine, the speed, the coverage, everything was fine. I connect to my ADSL via dial-up as im sure alot of you do. So I set up the network, with the IP's and everything, and then proceeded to connect to the internet. The first time it connected perfectly and as the connection minimized I tried to load the browser and my computer froze. So naturally I thought, little hiccup, won't happen again. So I rebooted tried it again, except this time it froze at "Verifying username and password." The computer just completely locked up, nothing I could do. So I tried everything I could to no avail. Eventually I went out and bought some no name brand wireless card that was just a PCI card, and it worked perfectly. I thought maybe it was because of my computer. So I wired up and old PC, it worked perfectly with the wireless card. I then tried it on my brothers computer which is also quite new. It did the same thing, just froze. A friend then came over and we tried the same with his computer, same thing, frozen. I have no idea what the problem is, I have tried everything I can think of, and I'm now sitting with three Belkin wireless cards, and no way to get a refund. If someone could please help, or suggest a reason as to why they don't work, it would be greatly appreciated. I would much rather use these new Belkin cards as apposed to the no name brander I bought, but I simply can't. Any help would be appreciated.
Thanks Guys.
pip
Gee - a horror! I am probably the last person able to help you, but an idea or 2. You say the Belkin cards work fine in the old PC? Are they different OS versions? Have you downloaded latest drivers? If they have such a setting, are the newer PCs set to PnP OS in the BIOS? Maybe there is an IRQ conflict or DMA one - try disabling the second com port ( shouldn't be an issue these days but who knows ). In the Control Panel Device Manager is there any problem showing?
Someone else with a freeze:
http://www.pcbanter.net/archive/index.php/t-872928-Belkin-Wireless-Card-freezes-win-xp-sp2.html
http://discuss.extremetech.com/forums/1004320423/ShowPost.aspx
http://www.circuitcity.com/ccd/prod...BV_EngineID=ccdgaddhlflmhedcfngcfkmdffhdfki.0
http://cnet.nytimes.com/Belkin_Pre_...&messageSiteID=7&messageID=984485&cval=984485
Only 157MB to d/l the drivers! :eek:
saixbot
Belkin Support
Hi mate, you may want to contact Belkin for assistance, their number is 0800991521
Regards
Stuart
StoneD0g
Thanks for the replies guys.
I have contacted Belkin, they had no clue what the problem was, not to my surprise. I thought it might be OS versions, the old PC was on SP1, So I re-installed SP1 on my PC, still no difference. I did notice however that when I installed windows with the PCI brdige card plugged in I got a lot of beeping when Copying system files and installed hardware. I believe the Route of the problem to be the PCI bridge card. I thought it might have been and IRQ conflict or something along those lines, but was unable to find anything. The PCI Bridge card is a RICOH - R5*** Something or other, I looked for drivers and found some but the website I found them on had broken links and attacked me with the most amount of spyware I have ever seen. So I really Am stumped, I still want to try and find more drivers for it, But Im quite sure it's not the Network card drivers that are the problem, it's the PCI Bridge card. Thanks anyway guys.
mic_y
StoneD0g, firstly I would recommend setting up the AP to work as a router. The Belkin should have this functionality. If it does, it would have a WAN port, that is next to the 4 LAN ports. Hook your DSL modem into that port, and then set up your router to connect to the DSL automatically. This should make your life a lot easier...
The thing is that both many of the manufacturers often make both the desktop and laptop cards the same, except that the desktop ones sit inside another card to convert it to PCI. This is normal and shouldnt be a reson for concern. Even my router (Gigabyte B49G) is actually a PCMCIA card in a pretty case with all the connctors neatly laid out. It makes a lot of sense for the companies to do that, as it saves on cost of running multiple production lines, and also makes it possible to change products according to demand.
Also pls infrom what OS'es you are running on the computers.
StoneD0g
I'm using Windows XP Pro SP2.
I did what you suggested the first time I started having these issues. It worked at first, however as soon as the internet ran for about 10 minutes it would drop. This also makes life a thousand times more difficult when it comes to changing accounts. Thanks for the input anyway. Pretty stumped as to what to do, I'm still positive that it is the PCMCIA Bridge card, I think it's conflicting with something on the PC's, or maybe with the OS itself.
Darth Garth
Well not quite ... in most routers these days you will find that that the PCMCIA form factor looking card that you see is actually the wireless component that uses a mini-PCI connector to hook up with the main router/switch CPU (Broadcom/Realtek/TI).
The Belkin Pre-N wireless desktop adapter has known issues with certain PC's because of the weirdo bridging it uses ... it is crap.
